Dev Tools
Dev Tools
Forum MOSFET IRFP9240
  • Subscribers 80 subscribers
  • Views 927 views
  • frontpage
MOSFET IRFP9240
srinivasansmv
srinivasansmv over 11 years ago
hello sir
     i have using mosfet irfp9240 for buck converter with driving totem pole configuration  and input frequency around 1khz only. if driving this method means rise time of signal is goes to very high and falll time is very low. mosfet not switching perfectly. can you tell me the reson for not switching properly. i have read one article . if you want MOSFET perfectly SWITCHING then calculate the gate require current. so can you tell me how to calculate the require gate current
    michaelkellett over 11 years ago
    We can't even begin to guess as to why it doesn't switch properly unless you post a schematic (as a .pdf or .jpg so everyone can read it).
  • srinivasansmv
    srinivasansmv over 11 years ago in reply to michaelkellett
    michaelkellett over 11 years ago in reply to srinivasansmv
    This circuit doesn't look like any buck regulator I know - where is the inductor ?
    Where did the circuit come from ?
    I'm on hols right now but if you post a description of what you want the finished regulator to do I'll see if I can help on Monday.
    (and just post in this group - don't post in the Eagle group as well because it isn't an Eagle problem.)
  • srinivasansmv
    as per our requirement output pulse vary from 0 to 60 volt pulsed mode
    condition and continouse mode of operation.  output require pulse as well
    as continouse . so only not come inductor capacitor. this is 60 v 7a and
    420W POWER supply as per my requirement
    On Fri, Dec 26, 2014 at 4:22 PM, michaelkellett <messages@element14.com>
    I think you need to explain properly what you are trying to do here. What is the load on your circuit ? Do you really want to be able to output  a variable pulse or steady voltage between 0 and 60V at 7A from a 60V supply?
    (If you do I hope you realise that the output device will need to be capable of handling 420W).
