Dev Tools
Dev Tools
Forum Run python script for HTML web page
  • Replies 9 replies
  • Subscribers 82 subscribers
  • Views 2777 views
Is there a way to run python script for html webpage? it's very important. i have a python script works fine in my raspberry Pi but i want to work with my home page,
how can i do that?
  • clem57
    clem57 over 11 years ago
    Yes, see this how to:https://wiki.python.org/moin/CgiScripts
    e14 Contributor over 11 years ago in reply to clem57
    OK becuase i'm new in that
    how can i plug in my python program file that it works fine to HTML. i want to run my python program on the net. i used raspberry pi to create the python program
    Please i want to know what's wrong in this html code to execute my python script via internet.
    <html>
    <head>
    <?php
    if (isset($_POST['LightON']))
    exec("sudo python /var/www/lighton.py");
    if (isset($_POST['LightOFF']))
    exec("sudo python /var/www/lightoff.py");
    <form method="post">
    <button class="btn" name="LightON">Light ON</button>
    <button class="btn" name="LightOFF">Light OFF</button><br><br>
        <br><br><br><br>
    </form>
    </html>
  • clem57
    clem57 over 11 years ago in reply to e14 Contributor
    <?php
    This has several issues:
    1. It looks to be PHP. Do you have this on your pi?
    2. Usually PHP is server side code and not visible on the client side or in the browser.
    3. Do you really really want to allow SUDO from the web? This is a hackers dream to see and exploit! A better although a bit complicated way would be to change a file like light.txt to on/off and let the python script read it in the background to perform the task.
    If you want a simpler way to control the light take a look at REST API in http://lmgtfy.com/?q=raspberry+pi+rest+server
  • clem57
    clem57 over 11 years ago in reply to clem57
    http://www.instructables.com/id/Building-a-Web-Enabled-Door-Lock-using-Rest-API-an/
    Thank you very much, i do have the python code, on my pi, i really do not care much about the security now, but i want to find a way to be able to control these 2 python code over the internet or intranet.
    if you could please help me out i would appreciated
    i forget to tell you that i do have Apache2 running with wordpress
    e14 Contributor over 10 years ago in reply to e14 Contributor
    Did you ever got to solve this??
  • nicole_94
    nicole_94 over 8 years ago
    hi, do you solve it? I have HTML page and will like to control my python script in the HTML. but not sure which step to do. as I search mostly say about framework
