Dev Tools
Dev Tools
Forum Need help with PCB design
  • Subscribers 81 subscribers
  • Views 787 views
Hello everyone, This is my first time posting on this website.
I would appreciate your help with a project that I have. I am learning how to design PCBs ans I created a small project just to test it out. Can you guys please check it and give me your feedback and your tips?
The project is on this link. I used PCBweb to create it
    shabaz over 10 years ago in reply to gadget.iom +3
    Also, this looked a bit weird, but was only noticeable when zoomed in on the top copper view. Since each pad is separated by 1.27mm, those very tiny joins between the pads look to be of the order of 0…
  • gadget.iom
    0 gadget.iom over 10 years ago
    First thing that stands out is that the Gnd trace on the pcb appears to short out between two pins on the IC.
    The GND connection count (in fact the schematic IC to PCB IC pin count) don't seem to match.
    It isn't clear what you are trying to achieve here.
    0 shabaz over 10 years ago in reply to gadget.iom
    Since each pad is separated by 1.27mm, those very tiny joins between the pads look to be of the order of 0.1mm or less.
    Patrick, there is a bigger learning curve with software like EAGLE, but it is exceedingly popular and so there are
    hundreds of video tutorials etc for it. You'd probably become proficient enough to create your own designs in a
    day or two of going through the user manual for it, and trying some tutorials.
    I am trying to make a PCB for the RFD 22301 with pads to solder wires or have sockets http://www.rfduino.com/wp-content/uploads/2014/03/RFD22301.Data_.Sheet_.11.24.13_11.38PM.pdf
    I would appreciate some tips and comments.
    0 shabaz over 10 years ago in reply to e14 Contributor
    Hi Patrick,
    I think one good option will be to use different connections for your breakout board (it seems this is what you're making) such as 0.1" header pins.
    Google 'breakout board' to get some ideas.
    Also, best to avoid online CAD packages unless you know there are solid well tried-and-tested good tutorials or support. I wouldn't have a clue how to create what
    you need using your online software, and probably not many others are vastly familiar with it either. On the other hand I can confirm there are hundreds or thousands of tutorials
    for the more traditional low-cost (or free) CAD tools such as EAGLE and KiCAD. Spending a couple of days familiarising with the user documentation and
    tutorials for one of these packages would be worthwhile.
