Dev Tools
Dev Tools
Forum Boot BBB from USB0
  • Answers 2 answers
  • Subscribers 82 subscribers
  • Views 2379 views
Boot BBB from USB0
I have started to work with the BBB and I have a question regarding the Boot sequence.
In default mode (S2 nor pressed) it is booting from eMMC as supposed.
I have created a new full image, loaded it in a SD card and when pressing S2 the system is booting from SD also as it is supposed.
Reading the documentation I see that pressing S2 the boot sequence is
  1. SPI0,
  2. MMC0 (microSD),
  3. UART0,
  4. USB0.
So I have loaded the same image in a USB pen drive, insert it in the mini USB connector (USB0 according to the layout) using a mini USB to USB adapter. The problem is that the system dos not boot, so I do not if I am missing something.
Any comment would be very helpful
Best Regards
    e14 Contributor over 10 years ago in reply to Nate1616 +1
    Nate, Thank you for your help. I think that it is not possible to do exactly what I was trying, and this links show what is possible to do if I want to startup from USB. Angel
  • Nate1616
    0 Nate1616 over 10 years ago
    Angel-
    Here are a couple good links that are doing exactly what you are trying to do. https://github.com/ungureanuvladvictor/BBBlfs and Beaglebone black USB boot - The Embedded Hobbyist
    Nate
  • clem57
    0 clem57 over 10 years ago
    Try a powered hub because it must be USB hard drive  that is self powered( can not be USB powered only )...
  • clem57
    Oh if you want to diagnose boot issues try AM335x board bringup tips - Texas Instruments Wiki
    0 e14 Contributor over 10 years ago in reply to Nate1616
    Nate,
    Angel
    0 e14 Contributor over 10 years ago in reply to clem57
    Hello Clem,
    Yes, I was thinking about booting issues. Now I think it is clear what we can do.
    Thank you
    Angel
