Dev Tools
Dev Tools
Forum Are you looking for a waterproof & miniature waterproof circular connector?
  • Subscribers 78 subscribers
  • Views 1869 views
  • small
  • lightweight
  • rohs-compliant
  • led
  • outdoor applications
  • measurement
  • fa robots
  • easymatingoperation
  • miniature
  • gps
  • hirose
  • waterproof
  • circular connectors
t.adegoke
t.adegoke over 5 years ago
Would Hirose's HR30 Series be suitable for your applications?
Our HR30 series are miniature waterproof plastic circular connectors that meet the requirement for outdoor electronic equipment.
The range consists of lightweight and small size plastic plugs, (including overmold type), receptacles, jacks, and accessories. Many varieties are available; the 3 and 6 contact versions are in a 12.6 mm diameter shell and the 10 and 12 contact versions are in a 15.5 mm diameter shell to give design flexibility. Further options include solder bucket, crimp, or through-hole contacts.
The innovative connector design incorporates gaskets, seals, and built-in strain relief to give IP67 or IP68 rated protection from dust and water penetration.
The user-friendly push-pull locking mechanism securely locks the mated connectors which are confirmed by an audible click. The connectors are simply pushed together and then quickly and easily disconnected by pulling on the plug’s release collar which has grooves to aid with the grip of the connector. Furthermore, visual white arrow alignment indicators and multiple polarizing keys ensure correct alignment and mating engagement. Minimal tooling is required for the simple assembly of the plug.
Ideal applications are servo motors, FA robots, GPS devices, measurement devices, LED lighting, and many more.
For more information click the below links:
HR30 series - HIROSE Electric Group [Connector]
https://nl.farnell.com/search?st=hirose%20hr30
imageHR30 Series_PR.pdf
