Dev Tools
Dev Tools
Forum Data Logger & Software combo needed
  • Replies 28 replies
  • Answers 2 answers
  • Subscribers 84 subscribers
  • Views 4232 views
  • 8_bit
  • 32_bit
  • 16_bit
  • microcontrollers
  • embedded
  • development
  • microcontroller
Catwell over 16 years ago
I am in the urgent need of a Data Logger / Data acquisition module with companion software. One stipulation, I need the software to be comfigurable without programming.
What have you used? What's good? I need any and all options.
Cabe
    0 michaelkellett over 16 years ago in reply to Catwell
    What about the Agilent  U2353AU2353A or one of the others from that range Neat little box USB no display I've got a  U2356AU2356A which is pretty good I bought it when I got fed up trying to get an NI board to work after 2 days of loading Gbyte drivers I still needed some other software horror I bought the Agilent thing and timed myself from opening the box to getting useful data on the PC about 20 minutes
    0 e14 Contributor over 16 years ago
    Cabe:
    If you are willing to do some programming on your own, you could try Sparkfun's Logomatic board - http://www.sparkfun.com/commerce/product_info.php?products_id=8627.  Programming of the onboard NXP LPC2148FBD64,151LPC2148FBD64,151 is through either the USB or the SD card.  Its limitation would be that the ADC is only 10 bit.  On the other hand, it has onboard storage and a built-in bootloader.  Sparkfun has written a little data logging program for the LPC2148FBD64,151LPC2148FBD64,151 - no PC interface, though.
    Steve Lindholm
  • Catwell
    0 Catwell over 16 years ago in reply to e14 Contributor
    Steve,
    Thank you for the idea of using the NXP LPC2148FBD64,151LPC2148FBD64,151. However, it is out of my time frame to make that work for me.
    My product is finished, currently using the Picotech solution. But, I recently found that the software "Picolog" is discontinued. So, looks like I am back on this quest.
    Cabe
    Hello Cabe,
    What makes you think that Picolog is no more ?
    Had a quick look at http://www.picotech.com/data-logging-software.html and it seems alive and well to me.
  • Catwell
    0 Catwell over 16 years ago in reply to michaelkellett
    Michael,
    Picotech told me, via email, that they are no longer going to do any updates to the software, and the tech support has moved to the forum area.
    Not quite the longevity I desire for a new product launch.
    Any thoughts?
    Cabe
    You're ahead of me there ! I can't think of anything closer to the Picos than the Agilent but it is more expensive.
  • KennyMillar
    0 KennyMillar over 16 years ago in reply to michaelkellett
    Although pico log recorder and log player may be going end of life (although I have to say, I see no mention of this on their site) I'm sure they will be replaced with something bigger and better.
    Looking at the current downloads on the pico site there is 'PicoScope 5 + PicoLog' and 'PicoScope 6' - so I'm guessing that the logging fucntions are now either in PicoScope or they are in something new still to be annouced.
    In addittion, all the pico data loggers have an SDK available which is very easy to use.
    You can write your own apps in C, or even directly inside Excel - examples are given.
    I've personally used several of their SDKs for both Oscilloscopes and Data loggers in recent past, and am currently working on a new product based around their TC-08 temperature probes. So I'd be willing to help you get to grips with the SDKs if you wish.
    -Kenny
  • Catwell
    0 Catwell over 16 years ago in reply to KennyMillar
    Kenny,
    Thanks for the research into the subject. I was unaware of Picoscope.
    I will definitely take you up on your offer. I will get back to you on the details soon.
    Cabe
