Dev Tools
Dev Tools
Forum Inexpensive relay need for LED project
  • Subscribers 80 subscribers
  • Views 373 views
  • dc-dc
  • power_management
  • power_distribution
  • knode
  • led
  • Design
  • power_supply
  • led_lighting
  • leds
  • power.power
  • relay
Latch
Latch over 14 years ago
I have a circuit that turns on an LED. Outputs approx 3v. Instead of turning on the LED, I want to trip a relay. On the other pole I will have a separate LED circuit consisting of a 9V battery, resistor, and set of 4 LEDs.
What I need is a cheap relay capable handling the above requirements.
Thoughts?
Latch
  • YT2095
    0 YT2095 over 14 years ago
    are you asking where to buy the relay from? or a cct to drive said relay from the bits you have?
    Farnell will likely sell such a relay, and to drive it you`ll need a simple NPN transistor like a BC108 or 2N2222A2N2222A, and resistor for the base so the 3V doesn`t overdrive it, and a bias resistor to pull it low.
    probably a good idea to have a reverse biased diode across the relay coil too.
    that`s about it really image
    edited to add: and don`t forget to make both grounds common for both power supplies.
