Dev Tools
Dev Tools
Forum interrupt help please! (CodeWarrior-related)~
  • Subscribers 80 subscribers
  • Views 376 views
  • interrupt
  • micro
  • codewarrior
DebuggerGuys
DebuggerGuys over 14 years ago
My problem is that interrupts don't work correctly.
I use CW 10.2 and the new micro 9s08PT60.
My interrupt function is:
interrupt VectorNumber_Vmtim1 void Vmtim1_ISR(void)
    MTIM1_SC_TRST = TRUE;        //    Interrupt flag reset
    PORT_PTED ^= 0x01;
After 2/3 times PTE0 changes status, the micro is reset.
Watchdog is disabled.
I tried with another interrupts, with #pragma TRAP_PROC, with "Interrupt vector table", but the result is the same.
Any idea?
Thanks! image
  • maudil
    0 maudil over 14 years ago
    can you supply the asm related code? In this way we can verify the correctness of the compiler configuration/results.
    Some compiler (like Cosmic) generate the .ls file that contain both the source code and the related asm generated code.
    Bye
