Dev Tools
Dev Tools
Forum cy8kit-049-4200 - problem using UART and I2C together
  • Subscribers 80 subscribers
  • Views 337 views
burkard99
burkard99 over 12 years ago
I have the cy8kit-049 board. Adding the "UART (SCB mode)[v1.20] component, I can build the  project and load the board. The uart loopback demo firmware works correctly - I can type characters via a terminal emulator and they are echoed back.
My problem:
      I when I add the I2C (SCB mode) [v1.20]component, the UART stops working correctly - the loop-back now echos garbage characters. The UART RX/Tx and I2C SDA/SCL are assigned different pins.
Can I not run 2 SCB components in a project??? Could someone help me out on this?
  • D_Hersey
    0 D_Hersey over 12 years ago
    I am not familiar with your particular processor.  My guess is that both functions are vying for a single shift-register.  In the worst case, you will not be able to use these functions simultaneously.
