Dev Tools
Dev Tools
Forum Read a VGA signal, handle it and use with a led matrix.
  • Replies 14 replies
  • Subscribers 80 subscribers
  • Views 2887 views
  • pic16
  • ledwall
  • led
Hello everybody, I'm new to this community but I came here from the ben heck show that is what I think is my wish to became in a near future image.
I am working on a project (for now it's only sketched on paper, there is nothing build yet) and I am looking for the best solutions to handle what I want to do. Basically the goal is to create a LEDWall to display some kind of video.
In my journey around the theme I find out that it's difficult to handle the fast signal coming form a VGA, first of all I thought about arduino to read the VGA signal, store only the part needed, and pass it to a 100x100 (or similar) LED matrix. The result was that arduino seems fast enough but it can't store a whole frame data in its memory so I am in trouble to process the signal.
The question is, is there something that can handle (read, store and process) the VGA signal and then drive a part of the led wall? I have many ideas in how to communicate between modules of the wall, but in some way I need to have also an IN/OUT ethernet connection to create a daisy-chain (this prevented me to use raspberry pi).
Few days ago I purchased from MicroChip a PIC16F887 that possibly can be used to my scope, I also purchased a 24FC1025 1024Mb memory that can be used with the pic to store a frame.
Can you guys help me with my ideas?
Gianmarco
    0 shabaz over 12 years ago
    This is a non-trivial project, but feasible - probably not just with a small PIC or arduino though. There is a book that will help. It's called Digital Video Electronics by Andrei Cernasov. It's quite old (and just averagely useful, not the best, but is practical-oriented), but some of the information is quite relevant. You'll need a fair bit of electronics knowledge (which you may already have).
    You could take a video and resize to 100x100 to see if you'd be satisfied with the results. Also, the cost/effort seems high for little benefit with such a low resolution.
    EDIT: Also see this URL for valuable information.
    0 e14 Contributor over 12 years ago in reply to shabaz
    Thank you for your answer, I will try to find that book, but what you mean "not just with a small PIC or arduino" ? It seems that in the link they are using some sort of programmable board similar to arduino, am I wrong? (unfortunately at the moment I am unable to read all the link)
    0 shabaz over 12 years ago in reply to e14 Contributor
    From what I briefly saw, they are using an ARM processor - and using DMA capability. The AVR based arduino devices won't be sufficient. The higher-end ones might be.
    I'm looking the link you gave me. It's absolutely interesting and maybe (if I understood what a OctoWS2811 do) is also daisychain capable, am I right? Using that, maybe changing the strips and creating a board ad hoc, I can imagine a big step forward for my project...
    Great, glad it helps. Yes, you can daisy-chain, those particular LEDs are extremely popular, many interesting projects using these.
    I was reading the link you gave me this afternoon and I noticed that all the system is based on a NeoPixel RGB led Strip that uses a WS2811 chip as driver for each led. One of the first thing is that create a big led wall with commercial leds product is far more expensive that buy a brand new one, so I was wondering if is there any place where to buy big stock of RGB leds and what driver I should use, in first place I thought I should address each led directly from the main board, using something like a cascade of decade counter to activate each led, that is using 3 out for R,G and B, one for HSync and one for the VSync.
    Maybe this can lead to persistence issues? or maybe I need a too fast board?
    The ws2811 (as specified in the datasheet) holds the data until a reset, is then necessary to have a single IC for each led? We are talking easily of more than 200.000 ICs! in case of a 600x400 screen. Is there any similar IC that can handle more Led at once? or even is there anything similar to the ws2811, because I can't find any site where buy them not to a final-user price
    The integrated circuit is inside each LED for the WS2812B devices. It is built-in. It's possible to buy these devices individually (not soldered in strips) too, in reels of hundreds or thousands, usually from China or Hong Kong (I don't have a source, I just obtained a small quantity from ebay but not used them so far).
    I was lookin in the net, but the only site that I found has a 100 pieces pack at 13$, for a 4x2,25 m wall (90000 led) is about 11.000$! I need absolutely to find a 10 time cheaper leds. Any Idea?
    Of course I can also win the lottery, but is like cheating image
    By the way, reading further the link, seems like the OctoWS2811 board don't concerne any kind of ethernet transmission, it only uses the cat6 cable to distribute 8 data signals. No Ethernet, no daisy chain... a step back for me, but indeed I have much more ideas.
    A factor of 10 cheaper (1.3 cent per LED) is unlikely to be possible. Even plain RGB LEDs (with no in-built controller) cost 31 cent each from Newark in quantities of 10000.
    90 000 LEDs each at 50mA will draw 4500 amps max at 5V, which is 22kW of power. This is not practical.
    there must be a solution, how can a commercial ledwall (more than 100.000 certainly) be powered then? Maybe I need smaller leds, not Hi lux...
