Dev Tools
Dev Tools
Forum typical connection schematic diagram
  • Replies 11 replies
  • Subscribers 82 subscribers
  • Views 1908 views
  • sensors
  • switches
  • motors
  • pifacedigital2
  • lights
  • relays
  • horns
  • digitali/o
why you are not providing typical connection schematic diagram for us to see before we buy it
    mcb1 over 11 years ago in reply to e14 Contributor +1
    Can you provide a link to the part you purchased. Mark
  • gadget.iom
    gadget.iom over 11 years ago in reply to e14 Contributor +1 verified
    And the picture is exactly the same module. I don't think element should be required to provide wiring diagrams for modules for items sold on Amazon, it would be impossible to provide diagrams for every…
  • gadget.iom
    You're welcome.
  • gadget.iom
    0 gadget.iom over 11 years ago
    Connection diagram for what?
    0 e14 Contributor over 11 years ago in reply to gadget.iom
    I had purchased items like single channel relay and two channel relay from element14 for using with arduino uno now I need help by a typical circuit diagram for making the connections to arduino to control a simple dc motor connected to 12v battery and arduino connected to pc usb port
    there are three pins on relay i.e for gnd,vcc and input on Left side of relay and three connectors on the right side for NO(normally open), common, NC(normally connected)
    I have a DC motor which can work with  the  battery with two terminals for 6V or 12v power output
    I connected
    GND to GND on arduino
    VCC to 6V battery one lead(+ side)
    motor connected between common and NC
    input pin coonected to GPIO pin 11 of arduino ( programmed to switch on and off in loop)
    the question is where to connect other end (-ve)of battery ?
    may be typical circuit diagram can help me to make the motor switch on/off controlled by the program loaded into arduino
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to e14 Contributor
    Well a quick google of "arduino single channel relay" yields: https://elementztechblog.files.wordpress.com/2014/07/relay-1_watermark.jpg
    0 mcb1 over 11 years ago in reply to e14 Contributor
    the jpg from google did not show any connections to either dc motor or external  power supply
    0 e14 Contributor over 11 years ago in reply to mcb1
    https://www.amazon.in/gp/product/B00LL0M6RS/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    is the link to the item purchased
  • gadget.iom
    I don't think element should be required to provide wiring diagrams for modules for items sold on Amazon, it would be impossible to provide diagrams for every possible use case.
    In your case the diagram is simple and I'll even make it up for you.
  • gadget.iom
    thank you very much for providing me required data. you are very nice  and very helpful
    my regards to you
    dvrrao@yahoo.com
  • gadget.iom
    You're welcome.
