Dev Tools
Dev Tools
Forum Use ranges with the product search API
  • Subscribers 78 subscribers
  • Views 3074 views
  • programming
  • development
  • dev
  • api
david_gomez
david_gomez over 3 years ago
I'm working right now on a collage project where I want to list certain components available at Element14 using the product search API to get them.
The specific issue I have is figuring out how to use the keyword search to filter as much as I can the results I will get from the API, an specific  example can be looking for inductors with an inductance with a minimum 90uh and a maximum of 110uh.
I don't know how to build the query URL (specifically the `term:any` param) for the API to return me the data I can get using the website filters.
Is there more in depth documentation on how to build the keyword search somewhere?
Can anybody with more experience using the API help me to understand if there is a better way to achieve what I need?
Thank you in advance for any help you can provide.
  • bidrohini
    bidrohini over 3 years ago
    Filter names and values may vary depending on the exact API version you are using and the specific product attributes available in the catalog.
    You can find more detailed documentation on the Element14 Product Search API here:partner.element14.com/docs
  • david_gomez
    david_gomez over 3 years ago in reply to bidrohini
    Thank you for the response bidrohini , I have been using the GET request for the keyword search, I'm not using any other type of request, so I'm not aware of the version of the API I'm using.
    Basically this is the request I'm doing:
    api.element14.com/.../products
    What I want to know is if there is any way I can use the keyword (term=any:inductor) in a more advance way to get more accurate results from the API? For example, using some of the possible attributes in the inductors like the inductance value.
  • david_gomez
    BTW, I already went through the entire documentation but there is nothing that suggests how or if I can do what I want to.
