Code Exchange
Code Exchange
Blog built gcc 15 daily release from source
Join Code Exchange to participate - click to join for free!
  • Author Author: Jan Cumps
  • Date Created: 1 Mar 2025 11:50 AM Date Created
  • Views 4008 views
  • gcc
  • Modern C++
  • c++26
  • object oriented
  • c++
Jan Cumps
Jan Cumps
1 Mar 2025
The latest GCC version is 14.2.1. I want to try out new GCC 15 features. I followed these instructions to build the toolchain from source: https://askubuntu.com/questions/1513160/how-to-install-gcc-14-on-ubuntu-22-04-and-24-04. They translate very well to the latest experimental source available as an archive, 6 days old GCC 15-20250223.
I installed Linux Lite (an Ubuntu derivative) on an older laptop. Building took a little more than a day. The only package that I had to install before building was flex, the fast lexical analyzer generator. Building that was easy. After the full toolchain build completed, I had this happy report:
I tested it from the command line with an existing OO project:  C++ callbacks and templates .
All worked Slight smile. Now I can try out some experimental features, such as "dual return". GCC 15 can return both a status and a value. This can make code that has to check if a call was successful, and that wants to retrieve a value (calculation, object,string), simpler
    DAB 9 months ago
    Nicely done.
    Jan Cumps 9 months ago
    Happily debugging in eclipse:
