Code Exchange
Code Exchange
Blog modern C++: function returns true / false, and a value or error message
Join Code Exchange to participate - click to join for free!
  • Date Created: 1 Mar 2025 6:08 PM Date Created
  • Views 1573 views
  • gcc
  • Modern C++
  • c++26
  • gcc15
  • c++
1 Mar 2025
I'm experimenting with new C++ constructs. GCC 15 implements an interesting concept of the C++26 standard: A function can return a status, and either a value or an error message.
Example is the standard std::to_chars() function. It will return a bool that reports success or failure, and it returns either the result, or error info.
Here is an example of how to use it:
    std::array<char, 5> str;
    if (auto [ptr, ec] = std::to_chars(str.data(), str.data() + str.size(), value))
        std::cout << std::string_view(str.data(), ptr) << '\n';
    else
        std::cout << std::make_error_code(ec).message() << '\n';
The function std::to_chars() returns true if successful, falls if failed, and you can get at the relevant response. We pass it a numerical value.  If successful, ptr points to the string representation of the passed value. If it failed (e.g. because the string representation does not fit in the buffer), ec contains a std::errc object that holds error information.
What's in it for us?
This can result in code that's easier to follow. An alternative to the style where error and result are passed via parameters. In traditional C++, you can either return a status flag, an "error value", or the "business value". The others would have to be writeable parameters (a reference or pointer).
With this new capability, the parameters are all inputs, and anything the function wants to report back, is part of the return value.
Discuss Slight smile
    Jan Cumps over 1 year ago in reply to DAB
    It's interesting for embedded designs, where the (great) exception handling infrastructure can be too expensive.
    Nothing done here can't be done in other good ways. But it's cheap on execution, and clean in your source code.
    DAB over 1 year ago
    This approach is an excellent way to build error detection and recovery capability into your software.
    If you control the way errors are handled, you can build more robust software.
