Does anyone knows where can I get PCB drilling machine plan.
I don't know of any plans and I suspect that it would be cheaper to just buy one.
What sort of PCB drilling machine do you want ?
There are lots of quite cheap 2 axis with drill kind of machines available.
https://www.aliexpress.com/w/wholesale-routing-machine.html
These people sell kits but a ready made machine is cheaper.
https://ooznest.co.uk/product/original-workbee-z1plus-cnc-machine/#size-colour
Also for many prototypes it is possible to just solder to the copper side, minus any drill holes (obviously for SMD of course, but also with through-hole parts, large DIP ICs too). Major benefit of saved time, and zero dust and drill bit breakages!
I want to build a press drill using "Spindle Motor" above 10000 rpm with minimum 500 watt or above power.
I have one of these https://www.axminstertools.com/proxxon-tbm-220-bench-drill-702060
It doesn't meet your spec.
500W at 10,000 RPM isn't safe for a small press drill - your brain is too close to the action when you are using it !
If you need this power and speed then you need a full blown router with X,Y,Z control and GUARDS on it.
Useful article here:
https://www.haraldkreuzer.net/en/news/lunyee-3018-pro-ultra-perfect-entry-world-cnc
There is this MPCNC CNC platform design by V1 Engineering.
