Dev Tools
Dev Tools
Forum Looking for some opinions
  • Subscribers 80 subscribers
  • Views 697 views
jlusco
jlusco over 8 years ago
So I created this Schematic and was wondering if people thought it would work and is laid out correctly?. It is a Lipo charging board.
    genebren over 8 years ago +1
    Jacob, The programing resistor (R1) goes to VSS (not Vin), so that needs to be corrected. Keep in mind that the part number has an extension that is unique for the battery chemistry. The part that you…
    Jacob,
    The programing resistor (R1) goes to VSS (not Vin), so that needs to be corrected.  Keep in mind that the part number has an extension that is unique for the battery chemistry.  The part that you need for Lipo is MCP73831-2 (4.2V end voltage).  I have used this chip a lot on consumer products and I have found it to be very sensitive to input voltage.  Be careful to minimize the input resistance (heavy gauge wires or think traces if on a PCB).
    Good luck,
    Gene
  • jlusco
    jlusco over 8 years ago in reply to genebren
    Thanks for the input
