Freedom development platform
  • Freedom development platform
Documents How to print floating values on KDS3.0 and KSDK1.2
Join Freedom development platform to participate - click to join for free!
  • Author Author: bheemarao
  • Date Created: 2 Sep 2015 12:28 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 8:41 PM
  • Views 838 views
Below is the tips for printing the floating values using KDS3.0 and KSDK1.2.0
While I was using FRDM-KL46Z freedom board to interface STBC-AGM01 sensor board i was suppose to print the sensor data (floating values) on UART terminal i tried to add below includes in the linker options
Cross ARM C++ Linker > Miscellaneous" > other linker flag>
"-nanolibc -u _printf_float" which did not worked as expected
so the solution to print floating values in KSDK is in  "print_scan.h" file
navigate to project folder > SDK > Utilities > src > print_scan.h as shown below
uncomment the line:
//#define PRINTF_FLOAT_ENABLE   1
to enable the printing of floating point variables.
just to test whether it prints floating value i had added fsl_debug_console component and assigned the TX/RX port pin and added below lines in main.c
then build your project and execute it ypu can see the floating point value printed on hyperterminal as shown below:
Happy Printing float values image image image
  • print_float_values
  • kds3.0
