Cypress Kits
  • Cypress Kits
Cypress Kits
Forum ILI9341 Library for PSoC 4 (8 bit Parallel Interface)
  • Subscribers 27 subscribers
  • Views 1377 views
I was wondering if you have a component or library to use a Graphic Display with ILI9341 that implements 8 bit parallel interface.
  • clem57
    clem57 over 10 years ago in reply to e14 Contributor +1
    Ater a posted, I realized so posted the complete datasheet. Most microprocessors use the SPI. Why did you go parallel?
  • clem57
    PSoC 5LP + ILI9341 240x320 TFT LCD | Cypress
    they have posted code here or Psoc 4.Cesar Guevara
  • clem57
    clem57 over 10 years ago in reply to clem57
    Details using dataset (a must have debugging) https://www.adafruit.com/datasheets/ILI9341.pdf
    Clem
    e14 Contributor over 10 years ago in reply to clem57
    Thank you Clem Martins, but I'm looking for 8 bit parallel interface but in the post from cypress is implmented using SPI
  • clem57
