Cypress Kits
  • Cypress Kits
Cypress Kits
Forum 50 projects done...50 more to go!!!
  • Subscribers 27 subscribers
  • Views 521 views
vandana
vandana over 13 years ago
We reached the milestone of 50 projects on the Cypress PSoC4 Pioneer Kit last week, and are moving strongly towards the 100 projects goa!!
The projects exhibit the limitless applications for the PSoC as a true programmable embedded system-on-chip integrating configurable analog and digital peripheral functions, memory and a microcontroller on a single chip.  The programmable analog resources - such as the SAR ADC, Op-amps can be configured easily through the PSoC Creator Software to be various analog components required to interface to sensors and other analog signals.
Here, I have attempted to put the projects in perspective of their applications to give the real essence of the versatility and scalability of the PSoC architecture.
We encourage the community to contribute their projects on the Pioneer kit, and also submit any requests and suggestions for project ideas to make this is a truly collaborative and learning experience.
Meet you all at the finish line....but remember the start is with the PSoC4 Pioneer KitPSoC4 Pioneer Kit
imageStarter Designsimage
Simple Blinking LED
CapSense Slider Exampleimage
PSoC 4 Pioneer Kit Annotation Libraryimage
What? I can use the PSoC 5LP too?image
imageAnalogimage
imageADCimage
Danger Shield with Light Sensor Control
Pioneer Board Oscilloscopeimage
2-Channel OScope with GraphicsLCDimage
Thermistor Exampleimage
imageDigitalimage
imageLED Controlimage
What was the value? - LED Memory Example
LED Memory! Part Deux. Just Deux it!
imageMotor Controlimage
Rise of the Machines (Rolling Robot)
Run Away Run Away! (Proximity Robot)
Stepper Motor Example
Obstacle Avoider Robot
Walk The Line! Robot Example
imagePWMsimage
Fractional Frequency Synthesizerimage
Two PWMs for the price of oneimage
imageSensorsimage
Ultrasonic Distance Measurementimage
Pioneer PnP Sensorsimage
“Paint The Night” Accelerometer Examplehttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/3718.contentimage_5F00_25425.html
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/1665.contentimage_5F00_25426.html
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/4807.contentimage_5F00_25427.htmlAudiohttps://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/3302.contentimage_5F00_25428.html
Danger Shield Buzzer of Doomhttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/4807.contentimage_5F00_25427.htmlMisc.https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/3302.contentimage_5F00_25428.html
More Relay!https://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html
https://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/1258.contentimage_5F00_25429.html
https://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/8105.contentimage_5F00_25430.html
https://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/6052.contentimage_5F00_25431.htmlCommunicationhttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/3817.contentimage_5F00_25432.html
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/4807.contentimage_5F00_25427.htmlWirelesshttps://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/3302.contentimage_5F00_25428.html
XBee Router Loopback Example
XBee Direct IO
XBee API RxTx Examplehttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html
XBee RGB CapSense Controlhttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html1
https://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html2
“WiFi? Why Not!” Arduino WiFi Shield Examplehttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html
Bluetooth Home Automation Systemhttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html
Bluetooth with GLCDhttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html
Android Phone Controlled Robothttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/4807.contentimage_5F00_25427.htmlWiredhttps://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/3302.contentimage_5F00_25428.html
Ethernet Shield
USB-I2C Utility
SD Card Mass Storage Device
USB-UART utility
tinyprintf Example
Sweet Music Everywhere! MIDI Shieldhttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html
UART, I2C, and SPI Joystick Examplehttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html
https://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/6052.contentimage_5F00_25431.htmlDisplayhttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/3817.contentimage_5F00_25432.html
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/4807.contentimage_5F00_25427.html7-Segmenthttps://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/3302.contentimage_5F00_25428.html
Danger Shield with 7-segment Display
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/4807.contentimage_5F00_25427.htmlGraphics LCDhttps://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/3302.contentimage_5F00_25428.html
Graphics LCD Display
LCD - Rotating Cube Demo
GLCD Paddle Game
Catch the Shells' Game with ColorLCD Shield
“Kill The Ghost” Game
PSoC With Friends! Word Scramble Gamehttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/4314.contentimage_5F00_25424.html
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/4807.contentimage_5F00_25427.htmlCharater LCDhttps://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/3302.contentimage_5F00_25428.html
Hangman Game
https://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/6052.contentimage_5F00_25431.htmlTouchhttps://community.element14.com/resized-image/__size/20x20/__key/communityserver-discussions-components-files/87/3817.contentimage_5F00_25432.html
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/4807.contentimage_5F00_25427.htmlCapSensehttps://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/3302.contentimage_5F00_25428.html
CapSense Button and LED Control with Bridge Control Panel
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/4807.contentimage_5F00_25427.htmlProximity
CapSense Proximity Detection
Proximity Theremin
https://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/4807.contentimage_5F00_25427.htmlResistive Touchhttps://community.element14.com/resized-image/__size/15x15/__key/communityserver-discussions-components-files/87/3302.contentimage_5F00_25428.html
Resistive Touch Example
  • jesusantoniocar
    jesusantoniocar over 13 years ago
    Hello vandana.
    Thanks for post this rojects by topics,  this allows easier locate the required application.
    Best regards,
    Jesus Antonio.
    DAB over 13 years ago
    Hi Vandana,
    So far I am very impressed with the versatility of the Psoc 4.
    I am hoping that we will see more detail about the programmable digital and analog components within the Psoc.
    Keep up the good work, the projects are very useful to assess the products capabilities.
