Cypress Kits
  • Cypress Kits
Cypress Kits
Forum Unable to find a solution for analog the routing
  • Subscribers 28 subscribers
  • Views 1071 views
zeroxone
zeroxone over 13 years ago
Hi!
     For my first time to using PSoC . I used to design project with MCU .
when i See Introduction about psoc4 , I quickly bought a development board.
       Because I feel it is very suitable for BLDC(sensor-less) design needs.......
It is easy to do some simple experiments with The PSoC Kits.
When I put the PWM( 6 digital pin) and reverse electromotive force(3 analog pin) are configured on the same time.
compile>>>>  Errors:Unable to find a solution for analog the routing
  • juanes.pazj
    juanes.pazj over 13 years ago +2
    take a look in the PSoC 4 pioneer kit guide PDF on the appendix you can find the pin assignment table, there are some pins already dedicated, you can also check the analog routing diagram on psoc creator…
  • cy.gul
    0 cy.gul over 13 years ago
    Hi Sanming,
    could you perhaps post your project here? it will be easier to debug your issue by looking at your implementation.
  • juanes.pazj
    0 juanes.pazj over 13 years ago
    imageCY8CKIT-042 PSoC 4 Pioneer Kit Guide_001-86371_0B_V.pdf
  • zeroxone
    0 zeroxone over 12 years ago in reply to cy.gul
    sorry
    When I post at that time, can't upload attachments.
    after that ,I did a lot of experiments and , I had solved that problem.::Analog circuit part cannot be arbitrarily wiring.
    Thank you for your reply.
