Cypress Kits
  • Cypress Kits
Cypress Kits
Documents Project #50  - SD Card Example (PSoC 4 Pioneer Kit Community)
  • Author Author: vandana
  • Date Created: 22 Jul 2013 5:11 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:27 AM
  • Views 2137 views
For details on the project code/application please click here
image50-SDCard_V1_0.pdf
50-SDCard_Mass_Storage_Example.zip
50-Project Images.zip
  • android
  • pioneer
  • pioneer_kit
  • psoc4
  • 100day
  • proximity
  • capsense
  • psoc_creator
  • cypress
  • psoc
  • Kabron
    Kabron over 11 years ago in reply to e14 Contributor
    Bug found:
    In the function SDCard_GetFileCount() maximum return value is 110 while the manual said:
    "The root directory typically contains 512 entries of 32 bytes each.  When using short filenames (DOS 8.3 format ), this means a maximum of 511 files listed"
    I made simply example(attached) that contain (D)ir command to test the problem.  To test you must have SDCard with more than 110 files in root folder.
    Should I create a case?
    Attaching failed. Here is the link:
    • https://drive.google.com/open?id=0BwK34EimhNEufmdGZ3dCWHBveGdCdkJDRTVSUGVVazRvUW5kWHZLX09SQmZPMlVmbDczdVE&authuser=0
    Vandana,
    Thank you for this project. I have tried to get this example to work with an Adafruit shield (http://www.adafruit.com/products/1141) without success. I have reworked the example project to ensure the pinout assignments are correct. In looking at main.c, I noticed at line 38: SDCARD_Select(SDCard_DISABLE). This would seem incorrect in trying to initialize the card. However, even after changing this to SDCARD_Select(SDCard_ENABLE), I appear to fall into an endless loop. Stumped....
