Single-Board Computers
  • Single-Board Computers
Blog Ethernet Lan Interface unit
  • Author Author: calssilva
  • Date Created: 17 Mar 2017 12:59 PM Date Created
  • Views 766 views
  • ehternet lan
calssilva
calssilva
17 Mar 2017
Hello,
Does anyone acknowledge the electric circuit below or recognize the protocol type which usually make use of the 48 pin connector ?
Any information about is welcomed !
Thanks in advance,
  • COMPACT
    COMPACT over 9 years ago
    Yes.
    It is a twisted pair physical interface for Ethernet.
    Check the manufacturer and part number of the black isolation transformer to find out its configuration.
  • hlipka
    hlipka over 9 years ago
    This is just an Ethernet breakout, with the necessary isolation transformer. So the protocol is 'ethernet'. You can trace the wires from the Ethernet jack to the transformer, and from there to the connector (I think then transformers are connected 1:1).
