Single-Board Computers
  • Single-Board Computers
Forum Windows 10 IOT
  • Replies 27 replies
  • Subscribers 61 subscribers
  • Views 5633 views
  • windows_10_iot
  • maaxboard
Windows 10 IOT
pthat
pthat over 6 years ago
Can the Windows 10 IoT Core be installed on the MaaXBoard Single Board Computer using the usual Windows 10 IoT Core Dashboard?
https://docs.microsoft.com/en-us/windows/iot-core/tutorials/nxp
Cheers
Sean
  • jafoste4
    jafoste4 over 6 years ago +2
    HI Sean, I am working on document that dictates the process for doing this for the MaaXBoard. I am hoping to have it available soon. -Josh
  • pthat
    pthat over 6 years ago in reply to jafoste4 +2
    jafoste4 Hi Josh We received the two boards we ordered today, great turn around seeing a lot of deliveries are delayed.due to the coronavirus. Nice little board and Booted up Linux image with no issues…
  • jafoste4
    jafoste4 over 6 years ago in reply to pthat +2
    Hi Sean, I received approval for posting over the weekend. It will be posted on E14 by EOW. In the mean time you can get it from here if you wish to get started sooner https://avtinc.sharepoint.com/:b…
  • pthat
    pthat over 6 years ago in reply to pthat
    Just had another go on a different machine.
    Clean install of VS 2017 and installed all the extras.
    Builds great and outputs FFU file, but still no boot.
    Have attached build log. and also uploaded to our server here http://ukcnc.net/MaaxBoard_iMX8M_2GB_TestOEMInput.xml.Release.ImageApp-log.zip
    Best
    Sean
  • jafoste4
    Hi Sean,
    I am currently looking into this.
    Wil get back to you.
    -Josh
  • jafoste4
    jafoste4 over 6 years ago in reply to jafoste4
    Hey Sean,
    Just  a heads up, im still working on this. I beleive its an issue with the uefi shell adn bootloader not being wrote by the image tool. Hopeing to have a resolution by EOW.
    -Josh
  • pthat
    Thanks Josh
    Looking forward to a update when you have got is sorted.
    Best
    Sean
  • pthat
    Hi Josh
    Any updates on this?
    Best
    Sean
  • pthat
    Another shout out to Josh ! image
    Any updates, would be great to start using the MaaXboard to test with hats we have here and our IOT code.
    Really do not want to roll back to using the Raspberry pi 2/3
  • jafoste4
    Hi Sean,
    I had to request a colleagues help on this issue. I am hopful to get it available to you this week. I am currently asking for an update on any progress. I'll let you know where we are on it come tomorrow.
    Thanks for being patient!
    -Josh
  • jafoste4
    Hi Sean,
    I got this back from my colleague today.
    I have been able to fix the boot issue, and pushed the new bootloader bits onto the github repo.
    I have identified on my board that the following sequence need to be applied before powering up the board :
    • Insert SDCard
    • Plug HDMI cable
    • Plug the power plug USB C Cable
    • Plug the Ethernet cable
    And when powering down I have to remove the power cable and also the HDMI cable before being able to restart the board.
    Also if the green led, located close to the 3 switches, is not on then for sure the platform won’t boot.
    The First boot is pretty long and consecutive boots are much more shorter.
    I will be testing the new commit myself this evening.
    -Josh
  • pthat
    Hi Josh
    Sorry to say that getting errors on the two computers that successfully compiled before with the new merge from Github.
    Even deleted local repository and re cloned to make sure it was clean. But compile errors.
    Is there a link to a FFU that you guys have compiled that I can download to test.
    Best
    Sean
  • pthat
    Cleaned down Visual Studio again and got it to compile.
    FFU created and works !
    No apps run as all compiled for ARM and not ARM64 so now got to work out in Visual Studio how to get ARM64 to appear.
    But at least it is up and running.
    Thanks Josh !
    Best
    Sean
