Single-Board Computers
  • Single-Board Computers
Forum Failed to Fetch the source
  • Replies 19 replies
  • Subscribers 58 subscribers
  • Views 5559 views
  • meta_maaxboard
  • maaxboard
marvintien
marvintien over 5 years ago
Fetch the source
Clone this repo
$cd sources
$ git clone http://192.168.2.149/imx8m/meta-maaxboard.git
Cloning into 'meta-maaxboard'...
fatal: unable to access 'http://192.168.2.149/imx8m/meta-maaxboard.git/': Failed to connect to 192.168.2.149 port 80: Connection timed out
Please tell me how to fix it? Thanks.
  • jafoste4
    jafoste4 over 5 years ago +1
    Hi Marvin, This was an issue on our end where the repo pointed to out internal development location. It has now been fixed and points to : $ git clone https://github.com/Avnet/meta-maaxboard.git Let me…
  • jafoste4
    jafoste4 over 5 years ago in reply to marvintien
    Hi Marvin,
    Are you getting anything on your screen? Are any of the leds on the board turning on? What SD Card are you using? What are you using as a power supply?
    -Josh
  • marvintien
    marvintien over 5 years ago in reply to jafoste4
    Hi Joshua:
    1. Are you getting anything on your screen?
        HDMI monitor is always black.
    2. Are any of the leds on the board turning on?
        Yes. Debian5 can normally boot from microSD card.
    3. What SD Card are you using?
       I am using "Team micrSD 500X 16GB", it functions well.
        https://24h.pchome.com.tw/prod/DGAG1C-A900987CE
    4. What are you using as a power supply?
       We bought this https://www.avnet.com/wps/portal/us/products/new-product-introductions/npi/avnet-maaxboard/
      The only power input is "USB Type C 5V/3A" , as describe in the  avnet-maaxboard's website.
    This Maaxboard probably has hardware's defect or malfunction, or poor design or poor quality....? I still don't know about it.
  • marvintien
    marvintien over 5 years ago in reply to marvintien
    Hi Joshua:
         I just download 02AndroidShipmentImage.zip and burn MaaXBoard-AndroidShipmentImage-SDcard-HDMI-V1.0.2r03.img to microSD card.
    The result is the same, it also can't run to Android  desktop. Only u-boot can output a NXP image to HDMI monitor.
  • marvintien
    Hi Joshua:
         Following is the dmesg after boot, the kernel-4.14.78 drm and hdmi driver's output messages.
    Everything seems to be O.K., except for "Unable to configure VS infoframe"?  It always is black screen on the HDMI monitor.
    ~# dmesg|grep hdmi
    [    1.156621] [drm] hdmi-audio-codec driver bound to HDMI
    [    1.161881] imx-drm display-subsystem: bound 32c00000.hdmi (ops imx_hdp_imx_ops)
    [    1.193401] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
    [    3.059859] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
    [    3.486272] imx-cdnhdmi sound-hdmi: i2s-hifi <-> 30050000.sai mapping ok
    [    3.486300] imx-cdnhdmi sound-hdmi: ASoC: no DMI vendor name!
    [    3.544223]   #0: imx-audio-hdmi
    [   10.946019] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
    ~# dmesg|grep drm
    [    1.055258] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    1.061906] [drm] No driver support for vblank timestamp query.
    [    1.068048] imx-drm display-subsystem: bound imx-dcss-crtc.0 (ops dcss_crtc_ops)
    [    1.075673] [drm] CDN_API_General_Test_Echo_Ext_blocking - APB(ret = 0 echo_resp = echo test)
    [    1.084216] [drm] CDN_API_General_getCurVersion - ver 13196 verlib 13062
    [    1.091032] [drm] Pixel clock frequency: 594000 KHz, character clock frequency: 594000, color depth is 8-bit.
    [    1.100965] [drm] Pixel clock frequency (594000 KHz) is supported in this color depth (8-bit). Settings found in row 27
    [    1.111818] [drm] VCO frequency is 5940000
    [    1.115933] [drm] VCO frequency (5940000 KHz) is supported. Settings found in row 14
    [    1.147585] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
    [    1.205615] [drm] Link rate is too high - forcing link to lower rate
    [    1.205667] [drm] Pixel clock frequency: 148500 KHz, character clock frequency: 148500, color depth is 8-bit.
    [    1.205675] [drm] Pixel clock frequency (148500 KHz) is supported in this color depth (8-bit). Settings found in row 16
    [    1.205679] [drm] VCO frequency is 5940000
    [    1.205685] [drm] VCO frequency (5940000 KHz) is supported. Settings found in row 14
    [    1.219625] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
    [    1.220117] [drm] Unable to configure VS infoframe
    [    2.026648] imx-drm display-subsystem: fb0:  frame buffer device
    [    2.033260] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
  • marvintien
    Hi Joshua:
    $ git clone https://github.com/Avnet/maaxboard-debian-build
    $ cd maaxboard-debian-build
    $ sudo ./debian_build.sh -b rootfs -f ./board/maaxboard/maaxboard.ini
    (But below errors occur:)
    Connecting to 192.168.2.100:80... failed: Connection timed out.
    Retrying.
    I still fail to build Debian5 image by myself because of the above error, is it possible to point the address of your Debian bsp repository to the external world?
    If it is, please kindly tell me how to modify "board/maaxboard/maaxboard.ini"? Thanks in advance.
  • jafoste4
    Hi Marvin,
    We are hoping to have this issue resolved by end of the week.
    Apologies.
    -Josh
  • marvintien
    Hi Joshua:
        O.K. I'm waiting for your good news. Thanks.
    Best Regards,
    Marvin
  • jafoste4
    Hi Marvin,
    This should be fixed now. Please let me know if you hit any further issues.
    Thx,
    Josh
  • marvintien
    Hi Joshua:
          Git clone from https://github.com/Avnet/maaxboard-debian-build and rebuild Linux kernel image are workable now.
    But it still can't run in to Debian window desktop via HDMI monitor.
    1. U-boot is calling maaxboard-dcss-hdmi.dtb as follows:
    $ cat uEnv.txt
    fdt_file=maaxboard-dcss-hdmi.dtb
    console=ttymxc0,115200 console=tty1 fbcon=rotate:0
    2. The following messages are hot-plugging in HDMI cable that connects HDMI monitor to maax-imx8mq board, the dmesg's output :
    [ 1117.243567] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
    [ 1117.249903] [drm] Link rate is too high - forcing link to lower rate
    [ 1117.256695] [drm] Pixel clock frequency: 148500 KHz, character clock frequency: 148500, color depth is 8-bit.
    [ 1117.243567] i.mx8-hdp 32c00000[ 1117.267057] [drm] Pixel clock frequency (148500 KHz) is supported in this color depth (8-bit). Settings found in row 16
    [ 1[ 1117.280877] [drm] VCO frequency is 5940000
    117.249903] [drm] Link rate is to[ 1117.288021] [drm] VCO frequency (5940000 KHz) is supported. Settings found in row 14
    [ 1117.267[ 1117.312470] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
    057] [drm] Pixel clock frequency [ 1117.320479] [drm] Unable to configure VS infoframe
    [ 1117.387623] dcss-core 32e00000.dcss: Configured video pll 2 with ref_clk 2 freq 148500000 (actual 148500000)
    [ 1117.989365] [drm] HDMI/DP Cable Plug In
    Best Regards,
    Marvin
