Single-Board Computers
  • Single-Board Computers
Forum Failed to Fetch the source
  • Replies 19 replies
  • Subscribers 58 subscribers
  • Views 5551 views
  • meta_maaxboard
  • maaxboard
marvintien
marvintien over 5 years ago
Fetch the source
Clone this repo
$cd sources
$ git clone http://192.168.2.149/imx8m/meta-maaxboard.git
Cloning into 'meta-maaxboard'...
fatal: unable to access 'http://192.168.2.149/imx8m/meta-maaxboard.git/': Failed to connect to 192.168.2.149 port 80: Connection timed out
Please tell me how to fix it? Thanks.
  • jafoste4
    jafoste4 over 5 years ago +1
    Hi Marvin, This was an issue on our end where the repo pointed to out internal development location. It has now been fixed and points to : $ git clone https://github.com/Avnet/meta-maaxboard.git Let me…
  • jafoste4
    Hi Marvin,
    Let me know if you run into any additional issues.
    -Josh
  • marvintien
    marvintien over 5 years ago in reply to jafoste4
    Hi Joshua,
        Thanks a lot. By now I can build yocto's image.
    But it seems that this yocto's image does not support X window desktop via HDMI monitor, please kindly tell me how to build the Debian image to support the support X window?
    or provide the datasheet.
    Marvin
  • jafoste4
    jafoste4 over 5 years ago in reply to marvintien
    Hi Martin,
    Have you looked under the technical documents section for the MaaXBoard? We have guides for rebuiding the debian sources.
    -Josh
  • marvintien
    Hi Joshua,
         I found this github site: https://github.com/Avnet/maaxboard-debian-build
    There are common.ini, maaxboard-lite.ini, maaxboard.ini under maaxboard-debian-build/board/maaxboard/
    I bought MaaXBoard with 2GB DDR, Quad core,  micro-SD slot.
    As follows, for option -b which .init file I should apply?  Thanks.
    sudo ./debian_build.sh -c rootfs -b ../board/maaxboard/maaxboard.ini
  • marvintien
    marvintien over 5 years ago in reply to marvintien
    Hi Joshua,
        In fact, I cannot find the technical document for rebuiding the debian sources.
    Please kindly tell me where I can get it. Thanks.
    Marvin
  • marvintien
    Hi Joshua,
    $ git clone https://github.com/Avnet/maaxboard-debian-build
    $ cd maaxboard-debian-build
    $ sudo ./debian_build.sh -b rootfs -f ./board/maaxboard/maaxboard.ini
    (But below errors occur:)
    Connecting to 192.168.2.100:80... failed: Connection timed out.
    Retrying.
    How can I modify "board/maaxboard/maaxboard.ini"?
  • marvintien
    Hi Joshua,
         I download and extract 02LinuxShipmentImage_Debian.zip, get MaaXBoard-LinuxShipmentImage-Debian-V1.1.1r10.img, and boot it from microSD card, but can't enter Debian Desktop environment. I wonder why? Please kindly reply me. Thanks in advance.
    B.R.
    Marvin
  • jafoste4
    Hi Marvin,
    The Desktop environment should work out of box. What are you utilizing as a display(HDMI or MIPI LCD)? Are you getting anything on the display?
    -Josh
  • jafoste4
    Hi Marvin,
    I have been out of office over the Holidays I am looking into this now.
    -Josh
  • marvintien
    Hi Joshua:
          I am using HDMI monitor to connect to Maaxboard and can't enter Debian5 Desktop.
