Single-Board Computers
  • Single-Board Computers
Forum can not auto startup chromium(chromium-ozone-wayland)
  • Subscribers 59 subscribers
  • Views 2876 views
gonewtinwind
gonewtinwind over 5 years ago
hi all,
I am playing imx8qm maaxboard board
I have added
chromium.service  at /etc/systemd/system/chromium.service
and make a link at /etc/systemd/system/multi-user.target.wants/chromium.service
it can run ExecStart=/bin/touch /aa.txt
after startup , I can find /aa.txt generated, it means the chromium.service running
but chromium not running.
anyway, I can manaully start up  chromium after log in
Why can not auto startup chromium ?
any help?
thank you.
my chromium.service file:
[Unit]
Description=launch chromium
[Service]
Type=oneshot
ExecStart=/bin/sleep 20
ExecStart=/usr/bin/chromium  --no-sandbox --gpu-no-context-lost --enable-gpu-rasterization --start-fullscreen --kiosk --no-first-run --incognito http://localhost:3300/rpi.html > /dev/null 2>&1 &
[Install]
WantedBy=multi-user.target
  • jafoste4
    jafoste4 over 5 years ago +1
    Hi, Try referencing these links. https://raspberrypi.stackexchange.com/questions/101733/raspberry-pi-4-autostart-chromium https://raspberrypi.stackexchange.com/questions/38515/auto-start-chromium-on-raspbian…
  • gonewtinwind
    gonewtinwind over 5 years ago in reply to jafoste4 +1
    I have find the solution. it's hard to do in systemd(maybe it's new for me): 1. create environmen file chromium first: cat /etc/default/chromium #OPTARGS="--xwayland --use-g2d=1" XDG_RUNTIME_DIR="/run…
  • jafoste4
    https://raspberrypi.stackexchange.com/questions/38515/auto-start-chromium-on-raspbian-jessie-11-2015
    https://raspberrypi.stackexchange.com/questions/15475/run-bash-script-on-startup
    Let me know if you have any success.
    Josh
  • gonewtinwind
    XDG_RUNTIME_DIR="/run/user/0"
    2. create a chromium.service file at /etc/systemd/system/chromium.service , put in the environmen file   like following:
    [Unit]
    [Service]
    User=root
    Type=oneshot
    EnvironmentFile=-/etc/default/chromium
    [Install]
    3. run: systemctl enable chromium or
    directly make a symbol link at :
    /etc/systemd/system/multi-user.target.wants/chromium.service -> /etc/systemd/system/chromium.service
    at  /etc/systemd/system/multi-user.target.wants/. to run ln -s  chromium.service  ../chromium.service  to make this link
    try to run systemctl start chromium to test. works well.
    power off and power on or restart . work well.
    done
    Thank you
  • vmate
    vmate over 5 years ago
    First, you should set the User option to your user to avoid running chromium as root, then set WantedBy to your DE's .target.
    Probably a better option would be to use your DE's autostart feature, made for this exact purpose of starting GUI programso on boot
  • gonewtinwind
    gonewtinwind over 5 years ago in reply to vmate
    hi @Mate Varga,
    how to avoid running chromium as root? I tried my time to run as myuser, eg:
    ExecStart=sudo -u myuser /usr/bin/chromium  --gpu-no-context-lost --enable-gpu-rasterization --start-fullscreen --kiosk --no-first-run --incognito http://localhost:3300/rpi.html > /dev/null 2>&1 &
    but can not be successful. so I have to use root user.
    how to write the chromium.service?
