Single-Board Computers
  • Single-Board Computers
Forum can I build maaxboard zeus branch now?
  • Subscribers 58 subscribers
  • Views 2673 views
gonewtinwind
gonewtinwind over 5 years ago
Hi Josh,
Can I build maaxboard zeus branch now?
it shows The "zeus" branch will support MaaXBoard / MaaXBoard Mini in the end of Dec 2020.
beacuse my old maaxboard source code can not support 18.5" mimo touchscreem,I found some discussions in nxp forum,imx8mqevk board can not support some hdmi screem. so  I am going to try a higher version. I am building
https://github.com/Avnet/meta-maaxboard/tree/zeus
  • gonewtinwind
    gonewtinwind over 5 years ago in reply to gonewtinwind +1
    Hi Josh, I have added optee sucessfully. at file ./meta-maaxboard/conf/machine/include/maaxboard-base.inc : MACHINE_FEATURES += " optee pci wifi bluetooth bcm43455" xtest passed! optee should work well…
  • gonewtinwind
    I found help here: https://github.com/OSSystems/meta-browser/issues/388 and add mesa in file : ./meta-browser/recipes-browser/chromium/chromium-ozone-wayland_75.0.3770.142.bb ... DEPENDS += "\ mesa \ libxkbcommon…
  • jafoste4
    jafoste4 over 5 years ago
    Hi Peter,
    Yes that is now public and tested. Also to make you aware, we are publishing a new yocto out of box image this week targeting this Zeus branch.
    -Josh
  • gonewtinwind
    gonewtinwind over 5 years ago in reply to jafoste4
    Hi Josh,
    Thank you very much for your reply so soon.
    I built it successfully by myself (I only modified an  ip adress to get kernel code from GitHub avnet, file ./meta-maaxboard/conf/layer.conf
    # Internal Git mirror
    #MAAXBOARD_GIT_HOST_MIRROR ?= "git://git@192.168.2.100/imx8m"
    # Github Mirror: github.com/Avnet
    MAAXBOARD_GIT_HOST_MIRROR ?= "git://git@github.com/Avnet"
    and the updated version can support my 18.5' mimo touchscreen(I am very happy at this time),
    but, unfortunately, the kernel can not support optee!
    I added DISTRO_FEATURES_append =" optee-os optee-test" in local.conf
    but it still does not  support optee. can not run xtest (no the executable code), can not find  /dev/tee* devices.
    do you know how to do?
    I remember the older 4.14.98  version should work(I will go back to test again).
    Maybe the zeus do not add the optee support right now? right?
    Thank you.
  • gonewtinwind
    Hi Josh,
    xtest passed! optee should work well.
    Tomorrow  I will add chromium. before I tried to add IMAGE_INSTALL_append +=" chromium-ozone-wayland" in local.conf, it did not pass the bitbake . it's stranger. I will try more.
    if it will OK too, I will update all my app to the version so that can support mimo 18.5 touchscreen
    Thank you
  • gonewtinwind
    sorry , the zeus branch can not pass chromium(IMAGE_INSTALL_append +=" chromium-ozone-wayland" in local.conf) compilation in ubuntu 18.04
    any help?
    ERROR: chromium-ozone-wayland-75.0.3770.142-r0 do_configure: Execution of '/home/rnd2/work/maaxboard/zeus/imx-yocto-bsp/maaxboard/build/tmp/work/aarch64-mx8m-poky-linux/chromium-ozone-wayland/75.0.3770.142-r0/temp/run.do_configure.12588' failed with exit code 1:
    ERROR at //build/config/linux/dri/BUILD.gn:11:20: Script returned non-zero exit code.
      dri_driver_dir = exec_script(pkg_config_script,
    Current dir: /home/rnd2/work/maaxboard/zeus/imx-yocto-bsp/maaxboard/build/tmp/work/aarch64-mx8m-poky-linux/chromium-ozone-wayland/75.0.3770.142-r0/chromium-75.0.3770.142/out/Release/
    Command: python /home/rnd2/work/maaxboard/zeus/imx-yocto-bsp/maaxboard/build/tmp/work/aarch64-mx8m-poky-linux/chromium-ozone-wayland/75.0.3770.142-r0/chromium-75.0.3770.142/build/config/linux/pkg-config.py --dridriverdir dri
    Returned 1 and printed out:
    Error from pkg-config.
    stderr:
    Package dri was not found in the pkg-config search path.
    Perhaps you should add the directory containing `dri.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'dri' found
    See //content/gpu/BUILD.gn:128:18: which caused the file to be included.
        configs += [ "//build/config/linux/dri" ]
    WARNING: exit code 1 from a shell command.
    ERROR: Logfile of failure stored in: /home/rnd2/work/maaxboard/zeus/imx-yocto-bsp/maaxboard/build/tmp/work/aarch64-mx8m-poky-linux/chromium-ozone-wayland/75.0.3770.142-r0/temp/log.do_configure.12588
    Log data follows:
    | DEBUG: Executing shell function do_configure
    | stderr:
    | ERROR: Execution of '/home/rnd2/work/maaxboard/zeus/imx-yocto-bsp/maaxboard/build/tmp/work/aarch64-mx8m-poky-linux/chromium-ozone-wayland/75.0.3770.142-r0/temp/run.do_configure.12588' failed with exit code 1:
    | stderr:
    ERROR: Task (/home/rnd2/work/maaxboard/zeus/imx-yocto-bsp/sources/meta-browser/recipes-browser/chromium/chromium-ozone-wayland_75.0.3770.142.bb:do_configure) failed with exit code '1'
  • gonewtinwind
    DEPENDS += "\
            mesa \
            libxkbcommon \
            virtual/egl \
            wayland \
            wayland-native \
    no the error appears,do_configure passed . now it is compiling.
    hope can pass the final compilation
    passed! works well!
    I do not how to run it by non root user, now root user run well!
