Single-Board Computers
  • Single-Board Computers
Forum yocto zeus branch toolchains compile optee_example code ,ModuleNotFoundError: No module named 'Crypto'
  • Subscribers 57 subscribers
  • Views 1555 views
gonewtinwind
gonewtinwind over 5 years ago
Hi all,
(maaxbaord sumo branch worked well).
I use yocto toolchains to cross compile optee_example code,
error happened:
from Crypto.Signature import PKCS1_v1_5
but I find in toolchain folder, the Crypto folder is there:
./sysroots/aarch64-poky-linux/usr/lib/python3.7/site-packages/Crypto
It seems the compiler can not find it ?
I have added :
IMAGE_INSTALL_append +=" python3-pycryptodome " in local.conf
any help?
About 2 year ago,I posted a similar question #3441 but that was in yocto bitbake process in early, could not generate the yocto image.
Today I play another board, I can build the image and the toolchain, the new issue is the toolchain compiler can not find the 'Crypto'
Thank you.
error:
aarch64-poky-linux-gcc -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=/opt/fsl-imx-xwayland/5.4-zeus/sysroots/aarch64-poky-linux -o optee_example_aes main.o -lteec -L/opt/fsl-imx-xwayland/5.4-zeus/sysroots/aarch64-poky-linux/usr//lib
make[1]: Leaving directory '/opt/oe/iw/iw-5.4.24/optee_examples/aes/host'
make -C ta CROSS_COMPILE="aarch64-poky-linux-" LDFLAGS=""
make[1]: Entering directory '/opt/oe/iw/iw-5.4.24/optee_examples/aes/ta'
CC aes_ta.o
CC user_ta_header.o
CPP ta.lds
LD 5dbac793-f574-4871-8ad3-04331ec17f24.elf
OBJDUMP 5dbac793-f574-4871-8ad3-04331ec17f24.dmp
OBJCOPY 5dbac793-f574-4871-8ad3-04331ec17f24.stripped.elf
SIGN 5dbac793-f574-4871-8ad3-04331ec17f24.ta
Traceback (most recent call last):
File "/usr/local/optee/sysroots/aarch64-poky-linux/usr/include/optee/export-user_ta_arm64//scripts/sign.py", line 78, in
main()
File "/usr/local/optee/sysroots/aarch64-poky-linux/usr/include/optee/export-user_ta_arm64//scripts/sign.py", line 31, in main
/usr/local/optee/sysroots/aarch64-poky-linux/usr/include/optee/export-user_ta_arm64/mk/link.mk:60: recipe for target '5dbac793-f574-4871-8ad3-04331ec17f24.ta' failed
make[1]: *** [5dbac793-f574-4871-8ad3-04331ec17f24.ta] Error 1
make[1]: Leaving directory '/opt/oe/iw/iw-5.4.24/optee_examples/aes/ta'
Makefile:9: recipe for target 'all' failed
make: *** [all] Error 2
  • gonewtinwind
    finally, I have found the solutions. I did  it 2 years ago for imx7 board. I remember again.
    do not need to modify the recipe.
    the toolchain does not include the Crypto package
    just manually copy Crypto to toolchain(I do not know how to modify somewhere in the compilation process to copy directly to make it, if someone knows how to do .please tell me ,thank you)
    sudo cp -r /home/rnd2/work/maaxboard/zeus/imx-yocto-bsp/maaxboard/build/tmp/sysroots-components/x86_64/python3-pycrypto-native/usr/lib/python3.7/site-packages/Crypto  /opt/fsl-imx-wayland-lite/5.4-zeus/sysroots/x86_64-pokysdk-linux/usr/lib/python3.7/site-packages/.
