Single-Board Computers
  • Single-Board Computers
Forum how to write a system service to auto startup chromium on wayland with non-root user?
  • Replies 8 replies
  • Subscribers 58 subscribers
  • Views 7273 views
gonewtinwind
gonewtinwind over 5 years ago
Hi Joshua  & all
I use the below system service can auto startup chromium on maaxboard wayland with root user, but it's not safe with root user, so I need to startup with non-root user.
I tried to modify it somewhere, but not work.
any help?
my service ,you can see it's root user with --no-sandbox option :
/etc/systemd/system/chromium.service
Description=launch chromium
[Service]
User=root
Environment=DISPLAY=:0
Environment=XDG_RUNTIME_DIR="/run/user/0"
Type=oneshot
ExecStart=/bin/sleep 15
ExecStart=/usr/bin/chromium --no-sandbox --disable-infobars --user-data-dir=/tmp/chromium --gpu-no-context-lost --enable-gpu-rasterization --start-fullscreen --kiosk --no-first-run --incognito http://localhost:3300/rpi.html > /dev/null 2>&1 &
[Install]
WantedBy=multi-user.target
ref:can not auto startup chromium(chromium-ozone-wayland)
  • jafoste4
    jafoste4 over 5 years ago +1
    Hi Peter, Did you have success in finding a solution to this? Here is our reccomendation " It could be specified one user in system service , For example, let user ‘avnet’ start this service, then modify…
  • jafoste4
    jafoste4 over 5 years ago in reply to gonewtinwind +1
    Hi Peter, This should solve your problem. Refer to the following steps to solve this problem: 1 start the weston desktop on maaxboard with ‘avnet’ user. (Refer to the guide in PDF form below for detailed…
  • jafoste4
    Hi Peter,
    It could be specified one user in system service , For example, let user ‘avnet’ start this service, then modify the property:
    [Service]
    User=avnet
    Another method is to delete the property ‘’ User=’’ , then any user could use the service.
    Josh
  • gonewtinwind
    gonewtinwind over 5 years ago in reply to jafoste4
    Hi Josh,
    no work!
    debug
    systemctl status chromium.service
    * chromium.service - launch chromium
       Loaded: loaded (/etc/systemd/system/chromium.service; enabled; vendor preset>
       Active: failed (Result: signal) since Tue 2021-05-25 18:47:53 UTC; 2min 26s >
      Process: 832 ExecStart=/bin/sleep 15 (code=exited, status=0/SUCCESS)
      Process: 833 ExecStart=/usr/bin/chromium --user-data-dir=/tmp/chromium --gpu->
    Main PID: 833 (code=killed, signal=TRAP)
    May 25 18:47:37 maaxboard systemd[1]: Starting launch chromium...
    May 25 18:47:52 maaxboard chromium[833]: [833:833:0525/184752.979981:ERROR:wayl>
    May 25 18:47:52 maaxboard chromium[833]: [833:833:0525/184752.980050:FATAL:ozon>
    May 25 18:47:53 maaxboard systemd[1]: chromium.service: Main process exited, co>
    May 25 18:47:53 maaxboard systemd[1]: chromium.service: Failed with result 'sig>
    May 25 18:47:53 maaxboard systemd[1]: Failed to start launch chromium.
    both following services:
    1
    [Service]
    User=myuser
    Type=oneshot
    ExecStart=/usr/bin/chromium  --user-data-dir=/tmp/chromium --gpu-no-context-lost --enable-gpu-rasterization --start-fullscreen --kiosk --no-first-run --incognito http://localhost:3300/rpi.html > /dev/null 2>&1 &
    [Install]
    2
    [Service]
    User=myuser
    Type=oneshot
    ExecStart=/usr/bin/sudo -u myuser /usr/bin/chromium  --user-data-dir=/tmp/chromium --gpu-no-context-lost --enable-gpu-rasterization --start-fullscreen --kiosk --no-first-run --incognito http://localhost:3300/rpi.html > /dev/null 2>&1 &
    [Install]
  • gonewtinwind
    gonewtinwind over 5 years ago in reply to gonewtinwind
    I posted NXP too, but no solutions.
    I tried to research online. but only old solutions for rc(old skills worked well before) not systemd.
    https://community.nxp.com/t5/i-MX-Processors/how-to-write-a-system-service-to-auto-startup-chromium-on/m-p/1275666#M1739…
    any suggestions?
  • jafoste4
    Hi Peter,
    1  start the weston desktop on maaxboard with ‘avnet’ user. (Refer to the guide in PDF form below for detailed example)
    2  create a service file and enable this service to automatically start Google Chrome
       maaxboard:~# vi /etc/systemd/system/chromium.service
    [Unit]
    Description=chromium Browser
    After=weston.service
    [Service]
    User=avnet
    Environment=XDG_RUNTIME_DIR="/run/user/1000"
    Type=oneshot
    ExecStart=/usr/bin/chromium --start-fullscreen > /dev/null 2>&1 &
    [Install]
       maaxboard:~# sudo systemctl daemon-reload
       maaxboard:~# systemctl enable chromium.service
    Note: in the chromium.service file , the number 1000 is the user's id.
    Use the command “id avnet” to get the user's id value
    3  reboot the system.
    Detailed guide see document - https://avtinc.sharepoint.com/:b:/t/ET-Downloads/EQCw2IF8l89Jo3yJokpDgHABeQbHIp2qwwOVyN759U4odg?e=ePHugh
    Thx,
    Josh
  • gonewtinwind
    hi Josh,
    Thank you very much.
    did you test it on your maaxboard(yocto-zeus)? I followed your guide, but it still does not work.
    debug info:
    systemctl start chromium.service
    [   88.067474] audit: type=1701 audit(1622567912.343:5): auid=4294967295 uid=1001 gid=1002 ses=4294967295 pid=831 comm="chromium-bin" exe="/usr/lib/chromium/chromium-bin" sig=5 res=1
    [   88.083553] audit: type=1701 audit(1622567912.351:6): auid=4294967295 uid=1001 gid=1002 ses=4294967295 pid=819 comm="chromium-bin" exe="/usr/lib/chromium/chromium-bin" sig=5 res=1
    Job for chromium.service failed because a fatal signal was delivered to the control process.
    See "systemctl status chromium.service" and "journalctl -xe" for details.
    -sh-5.0# systemctl status chromium.service
    * chromium.service - chromium Browser
       Active: failed (Result: signal) since Tue 2021-06-01 17:18:32 UTC; 7s ago
      Process: 819 ExecStart=/usr/bin/chromium --start-fullscreen > /dev/null 2>&1 >
    Main PID: 819 (code=killed, signal=TRAP)
    Jun 01 17:18:32 maaxboard systemd[1]: Starting chromium Browser...
    Jun 01 17:18:32 maaxboard systemd[1]: chromium.service: Main process exited, co>
    Jun 01 17:18:32 maaxboard systemd[1]: chromium.service: Failed with result 'sig>
    Jun 01 17:18:32 maaxboard systemd[1]: Failed to start chromium Browser.
    lines 1-10/10 (END)
  • jafoste4
    Hi Peter,
    I will verify the OS used.
    Can you share similiar screen captures as shown in the user guide provided to make sure we are on the same page?
    Thx,
    Josh
  • gonewtinwind
    my commands:
    NXP i.MX Release Distro 5.4-zeus maaxboard ttymxc0
    maaxboard login: [   22.879528] Atheros 8035 ethernet 30be0000.ethernet-1:04: attached PHY driver [Atheros 8035 ethernet] (mii_bus:phy_addr=30be0000.ethernet-1:04, irq=POLL)
    [   25.954678] fec 30be0000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   25.962474] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   25.988602] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.1: link becomes ready
    [   26.003080] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.2: link becomes ready
    root
    Password:
    Last login: Tue Jun  1 17:29:08 UTC 2021 on tty7
    -sh-5.0# useradd avnet
    -sh-5.0# passwd avnet
    New password:
    Retype new password: [   67.986464] audit: type=1006 audit(1622568601.259:3): pid=783 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
    passwd: password updated successfully
    -sh-5.0# usermod -aG video avnet
    -sh-5.0# groups avnet
    video avnet
    id avnet
    uid=1001(avnet) gid=1002(avnet) groups=1002(avnet),44(video)
    -sh-5.0# cat /etc/systemd/system/chromium.service
    [Unit]
    [Service]
    User=avnet
    Environment=XDG_RUNTIME_DIR="/run/user/1001"
    Type=oneshot
    [Install]
    [  361.369813] systemd-fstab-generator[803]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [  361.384935] systemd-fstab-generator[803]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [  361.400019] systemd-fstab-generator[803]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [  361.415015] systemd-fstab-generator[803]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [  361.430032] systemd-fstab-generator[803]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [  361.445022] systemd-fstab-generator[803]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [  361.460009] systemd-fstab-generator[803]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [  361.474984] systemd-fstab-generator[803]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [  361.489958] systemd-fstab-generator[803]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [  361.504923] systemd-fstab-generator[803]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [  361.521806] printk: systemd-fstab-g: 15 output lines suppressed due to ratelimiting
    Created symlink /etc/systemd/system/multi-user.target.wants/chromium.service -> /etc/systemd/system/chromium.service.                      (see here: the link generated, the following errors is not for it)
    [   94.334139] systemd-fstab-generator[805]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [   94.349296] systemd-fstab-generator[805]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [   94.364402] systemd-fstab-generator[805]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [   94.364491] systemd-fstab-generator[805]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [   94.364577] systemd-fstab-generator[805]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [   94.364661] systemd-fstab-generator[805]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [   94.364750] systemd-fstab-generator[805]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [   94.439157] systemd-fstab-generator[805]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [   94.454146] systemd-fstab-generator[805]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [   94.469121] systemd-fstab-generator[805]: Failed to create unit file /run/systemd/generator/run-media-sda1.mount, as it already exists. Duplicate entry in /etc/fstab?
    [   94.485944] printk: systemd-fstab-g: 15 output lines suppressed due to ratelimiting
    after reboot or power off/on:
    [   66.891113] audit: type=1701 audit(1622569050.163:4): auid=4294967295 uid=1001 gid=1002 ses=4294967295 pid=802 comm="chromium-bin" exe="/usr/lib/chromium/chromium-bin" sig=5 res=1
       Active: failed (Result: signal) since Tue 2021-06-01 17:37:30 UTC; 8s ago
      Process: 802 ExecStart=/usr/bin/chromium --start-fullscreen > /dev/null 2>&1 >
    Main PID: 802 (code=killed, signal=TRAP)
    Jun 01 17:37:29 maaxboard systemd[1]: Starting chromium Browser...
    Jun 01 17:37:30 maaxboard chromium[802]: [802:802:0601/173730.165212:ERROR:wayl>
    Jun 01 17:37:30 maaxboard chromium[802]: [802:802:0601/173730.165287:FATAL:ozon>
    Jun 01 17:37:30 maaxboard systemd[1]: chromium.service: Main process exited, co>
    Jun 01 17:37:30 maaxboard systemd[1]: chromium.service: Failed with result 'sig>
    Jun 01 17:37:30 maaxboard systemd[1]: Failed to start chromium Browser.
  • gonewtinwind
    anyway,I did the way as your guide many times in both maaxboard and iwave  before, but did not work! I asked the same question on NXP, but there was no solution either
