Single-Board Computers
  • Single-Board Computers
Forum How do I upgrade the Qt version ?
  • Subscribers 58 subscribers
  • Views 1249 views
  • yocto
  • yocto image build
  • qt5
  • qt5-meta-lay
  • maaxboard
akoc
akoc over 5 years ago
Hello all,
The Qt version is 5.10.1 in the system I am currently using. Can I upgrade to 5.15? And how do I include all packages of qt in my system?
When I try to compile my application and run it on my device, I get the following error.
QQmlApplicationEngine failed to load component
qrc:/...:55 module "QtQuick.Extras" is not installed
qrc:/...:53 module "QtQuick.Controls" is not installed
qrc:/...:54 module "QtQuick.Controls.Styles" is not installed
I think if I upgrade the qt version I will solve this problem. Am I wrong?
My device,
Maaxboard
https://www.avnet.com/shop/us/products/avnet-engineering-services/aes-mc-sbc-imx8m-g-3074457345642080716?INTCMP=AMER-ECOMM-AVNET-BOARDS-AVT-INT-WEB- MAXBOARD-PRODUCTS-08282020
My build tools
https://github.com/Avnet/meta-maaxboard?ICID=maaxboard-datasheet-widget
  • jafoste4
    0 jafoste4 over 5 years ago
    It does appear the QT installed on the based OS is giving you issues with your application. Does QT 5.15 have the missing modules?
    -Josh
  • akoc
    0 akoc over 5 years ago in reply to jafoste4
    I solved this problem by adding the following packages to my configuration and compiling image and sdk again,
    ... / conf / local.conf
    PACKAGECONFIG_append_pn-qtbase = "accessibility"
    PACKAGECONFIG_append_pn-qtquickcontrols = "accessibility"
    IMAGE_INSTALL_append = "\
    qtdeclarative-qmlplugins \
    qtconnectivity-qmlplugins \
    qtlocation \
    qtlocation-plugins \
    qtlocation-qmlplugins \
    qtlocation-examples \
    cinematicexperience \
    cairo pango fontconfig freetype pulseaudio dbus \
    alsa-lib alsa-tools alsa-state fsl-alsa-plugins alsa-utils \
    i2c-tools \
    qtquickcontrols-qmlplugins \
    qtquick1 \
    qtscript \
    qtquickcontrols2 \
    But when i run the application i get the following error
    $ ./dashboard -platform wayland
    Failed to create display (No such file or directory)
    But i am sure my application is working. I'm printing something to the console in the software
    I can run my application with the following command,
    . $ / dashboard -platform minimal
    qml: 0.00003289866931044383
    qml: 0.003289747877317506
    qml: 0.010657910391161929
    qml: 0.022234013618702142
    qml: 0.03801480781383593
    qml: 0.05799586285241243
    qml: 0.08053782012851507
    qml: 0.10863987105831696
    qml: 0.14307861455023219
    qml: 0.1773762133457918
    qml: 0.22066755437882057
    qml: 0.2656912390696692
    qml: 0.3148512692620531
    qml: 0.3681338443174037
    qml: 0.4255240062798904
    qml: 0.4870056440755516
    But i can't view the interface.
    Platforms in the system
    minimal, offscreen, vnc, wayland-egl, wayland.
