Single-Board Computers
  • Single-Board Computers
Forum will mipi and hdmi display work simultaneously
  • Subscribers 57 subscribers
  • Views 1090 views
gunsamtech
gunsamtech over 5 years ago
I need to see a graph both mipi touch screen and hdmi monitor connected to the board simultaneously. is this possible with this board.
i have android os 9 in this
  • jafoste4
    jafoste4 over 5 years ago +1
    Hi Ganesh, On the SD card you specifiy if you want to use the DTB with the MaaXBoard HDMI interface or the MIPI Display enabled. It is possible to run them at the same time but will take some effort on…
  • jafoste4
    0 jafoste4 over 5 years ago
    Hi Ganesh,
    On the SD card you specifiy if you want to use the DTB with the MaaXBoard HDMI interface or the MIPI Display enabled. It is possible to run them at the same time but will take some effort on your end.
    For instance refer to this guide. https://imxdev.gitlab.io/tutorial/How_to_use_dual_display_on_i.MX8_including_4k_decoding/
    -Josh
