Single-Board Computers
  • Single-Board Computers
Forum Homemade CNC Software
  • Replies 10 replies
  • Answers 4 answers
  • Subscribers 59 subscribers
  • Views 1710 views
gtrplyer16
gtrplyer16 over 12 years ago
So I'm building/designing a CNC from scratch and was wondering if anyone could give me any suggestions on software to use and different ways to control them. Be it an Arduino or Raspberry pi or even Mach 3 with a laptop. I'm not sure what would work best. Suggestions greatly appreciated!
  • element14jamie
    element14jamie over 12 years ago in reply to gtrplyer16 +1
    Hello gtrplyer16, No worries at all, I hope you enjoy it here. Thank you, Jamie
  • element14jamie
    0 element14jamie over 12 years ago
    Hello gtrplyer16,
    Welcome to the element14 Community, we hope you enjoy it. I will move this to the Single Board Computers area as it is a better fit to your question.
    Thank you,
    Jamie
  • gtrplyer16
    0 gtrplyer16 over 12 years ago in reply to element14jamie
    Thank you. I'm new to element14 and wasn't sure which would be best.
  • element14jamie
    0 element14jamie over 12 years ago in reply to gtrplyer16
    Hello gtrplyer16,
    Thank you,
    Jamie
    0 shabaz over 12 years ago
    Hi Tyler,
    Probably you want the most reliable method possible otherwise it will be quite dangerous. I think it would need something with a fair bit of processing power (to accelerate/decellerate correctly). I think it would be best to refer to CNC forums to be honest, to see what bits of hardware and software are known to be reliable, unless you plan on developing your own HW/SW combination. I doubt Arduino will have the processing power (unless you plan on using it just as an interface to a larger PC), and the RPI will not be a safe option here either.
  • gtrplyer16
    Thank you shabaz! I will check out the forums now. I have been seeing "Mach 3" but wasn't sure if that would be the simplest for being a starter to designing a CNC. I've never done anything of this magnitude yet and appreciate your input!
    0 shabaz over 12 years ago in reply to gtrplyer16
    Hi Tyler,
    No problem, I hope it goes well, it sounds like an interesting challenge!
    Some useful starting points:
    http://www.linuxcnc.org/
    http://blog.machinekit.io/
    Machinekit has been tailored for the BBB and I believe it uses the PRUs for some of the hard stuff, so availability of a BBB may be a problem. But yes, there is software available to do this sort of thing.
  • jiminlexky
    0 jiminlexky over 8 years ago
    I use LinuxCNC for my table.  Highly recommended.
    Also check out:
    www.openbuilds.com
    and
    buildyourcnc.com
    for hardware.
    LinuxCNC will drive up to 7 axis and is well supported.
  • gam3t3ch
    0 gam3t3ch over 8 years ago
    I use uno r3 with cnc shield on a pi 2 running universal gcode sender
    A mega with ramps 1.4 is also a option with marlin which I will be playing with soon on my laser engraver soon.
    0 DAB over 8 years ago
    Welcome Tyler,
    There is an old Ben Heck Show episode where he implemented his first CNC using an Arduino.
    You might want to look it up.
    The controller just needs to properly decode the Gcode and drive the various motors to do the work as commanded.
    The MCU selected is mostly about how fast you need the job done and that issue also depends upon the hardware capability you have and the material you intend to work with.
