Single-Board Computers
  • Single-Board Computers
Forum BBB Debian vs. Angstrom
  • Subscribers 60 subscribers
  • Views 1258 views
rmele14
rmele14 over 12 years ago
I want to switch to Debian but I'm afraid!.. I've written a few PRU programs and use the gpio libs. Will I need to relearn how to access the PRU and the device tree for Debian? I was a pain to learn for Angstrom.
    Along that line, can you guys tell us the main differences between the two, please?  Guess we should stay with the 3.18 kernel on both, for a proper comparison.
    Thanks.
  • rmele14
    0 rmele14 over 12 years ago in reply to e14 Contributor
    I don't know the differences, but Debian has wider support. It's considered mainstream. I did switch and everything I did before, including the PRU code works.
  • frogger
    0 frogger over 12 years ago in reply to rmele14
    I am having trouble telling the difference.
    Some minor differences:
    The time protocol client is active by default on the new Debian distribution, whereas you had to enable it on Angstrom.
    The source code for the device tree files is in a different folder.
    All my previous source code runs as before on the new BBB Debian distribution.
    The distribution is larger.  Debian pretty much fills 2 GB of memory.  So I don't think you
    would be happy running Debian on the 2 GB Flash version of BBB. Probably stick
    with Angstrom if you are running a 2 GB BBB.
    Either Angstrom or Debian should run fine on the 4 GB version.
    If you are adding an overlay device tree file, you need to do it from "root", rather
    than the user "debian."  The allowed activities that "sudo" is allowed, as a user, is more
    restricted under Debian.  If you log in as "root", no issues as compared to before.
    --- Graham
  • happyduino
    0 happyduino over 10 years ago
    So.. which one is faster to startup? Without the GUI (that is, you remove the GUI on both Debian and Angstrom).
    What is the start-up time comparison?
