Single-Board Computers
  • Single-Board Computers
Forum turning a robots head towards your voice
  • Replies 7 replies
  • Subscribers 59 subscribers
  • Views 1183 views
skypickle
skypickle over 8 years ago
Just as the amazon echo has an led ring that points to the source of your voice, i would like to drive a stepper motor that turns the robots head.
As this would require a far field microphone array, i have found two boards that offer this functionality
The respeaker microphone array
https://www.amazon.com/gp/product/B071S2ZMSQ/ref=ox_sc_act_title_2?smid=A1YP59NGBNBZUR&psc=1
the matrix creator
https://www.matrix.one/products/creator
So although
I have basic arduino/rasbPi experience, I have no real hardware expertise. The speaker would require purchase of the core unit as well so it would be somewhat more expensive. But I do not know how to compare these two hardware platforms.
Has anyone any familiarity with this hardware?
Has anyone seen this problem solved before (so I dont need to reinvent the wheel)?
I have investigated 'homegrown'solutions using individual mics whose signals are compared and using phase differences to determine a direction(the mic closer to the sound source gets the signal sooner). However, this is not accurate when identifying a sound impulse and requires a continuous or repeating sound.
  • abrain
    abrain over 8 years ago +1
    I don’t know how accurate you want to be, or your programming experience, but I‘d be tempted to try 3 microphones in a triangular arrangement, each feeding a basic peak hold circuit with quite a slow release…
    shabaz over 8 years ago +1
    Hi Stefan, On paper, both will excel. For your described purpose alone, ReSpeaker will possibly have the edge, but it is likely harder to use. For additional functionality, Matrix Creator will have the…
    shabaz over 8 years ago in reply to skypickle +1
    Hi Stefan, That product is dedicated to that task, and the chip vendor (XMOS) has significantly invested (i.e. in $$$$) in specific voice technologies. However, it is likely more difficult to use for a…
  • abrain
    I don’t know how accurate you want to be, or your programming experience, but I‘d be tempted to try 3 microphones in a triangular arrangement, each feeding a basic peak hold circuit with quite a slow release rate, and using those 3 peak held signals as inputs to trigger interrupts. The interrupt that comes first would indicate the direction to turn towards.
    The peak hold is intended to slow down the rate of interrupting, so I’d go with it decaying over say 200ms or so.
    it might be a bit too crude for your purposes, but it would be reasonably simple to put to the test I’d think?
    A
  • skypickle
    skypickle over 8 years ago in reply to abrain
    from what I've read, using one two or three mics requires them to be far apart. and then you need a processor able to handle all that processing - more than an Arduino or a pi can handle. Rather a dsp chip is needed. you don't mention what hardware you would use. How would you design this?
    Hi Stefan,
    On paper, both will excel. For your described purpose alone, ReSpeaker will possibly have the edge, but it is likely harder to use. For additional functionality, Matrix Creator will have the edge.
    If you're a newcomer, between the two I'd suggest Matrix Creator. Both are a huge leap in audio capability in recent years available for developers, so in theory you possibly won't be disappointed by either.
    You should check out the github location first though, so you're aware approximately of how to code with it.
    Disclaimer: I've not used either of these products, so this is just based on what I've briefly read/heard.
  • skypickle
    skypickle over 8 years ago in reply to shabaz
    thank you shabaz for ur reply. can you elaborate on the reasons you said respeaker is better for my purpose?
    Hi Stefan,
    However, it is likely more difficult to use for a beginner (I don't know your skill level).
  • beacon_dave
    beacon_dave over 8 years ago
    May be of some interest. A couple of three microphone impulse tracker projects by Cornell students on the ECE 4760 AVR microcontroller course.
    Impulse sound tracker
    https://www.youtube.com/watch?v=hxsMbl1AFXw
    ECE 4760 Acoustic Impluse Marker
    Sound-localizing camera
    https://www.youtube.com/watch?v=erwi-TFy5Dk
    ECE 4760 Sound-localizing Camera
    mcb1 over 8 years ago
    If you were able to make the microphones directional, then you could do something along the lines of light sensors.
    Using abrain idea of peak holding the signal from each one, it would be aparent that the sound level is higher in a certain direction.
    I was thinking that one in the centre and one on each side aimed about 45 degs may have enough difference.
