BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Blog Do you need an umbrella today?
Join BeagleBoard to participate - click to join for free!
  • Author Author: markvenn
  • Date Created: 1 Dec 2014 10:55 PM Date Created
  • Views 982 views
  • python
  • mark_venn
  • weather
  • beaglebone-black
markvenn
markvenn
1 Dec 2014
I have been working on an idea for my project. I am using my BBB to get the weather forecast and to let me know if I need to take an umbrella when I go out. (To be honest I don't use an umbrella but this is is for a "proof of concept" idea). image
I am using python here to collect the forecast from Weather Underground, the api page is very helpful, and when I have the forecast as a json document I can extract the data I am looking for and do stuff with it. Currently I am displaying the weather forecast form my local area for the day that the program is being run and the next day. I have coded the place that I want the weather for into the string that makes up the URL, as my project is going to be setup per user I think that this is OK. See code below:
# program to grab the weather forecast from weather underground
# author Mark Venn
# based on code from "Getting Started with Raspberry Pi"
# currently collects the forecast for current day and next day. Lights an LED if the chances of rain are over 60%
# imports
import requests
import Adafruit_BBIO.GPIO as GPIO
import time
# configure GPIO pins
GPIO.setup("P8_8",GPIO.OUT)
GPIO.output("P8_8",GPIO.LOW)
# wunderground api key
key = 'xxxxxxxxxxxxxxxx'
# build string using hard coded web address & api key variable
ApiUrl = 'http://api.wunderground.com/api/' + key + '/geolookup/forecast/q/UK/Bembridge.json'
while True:
    # get the weather forecast from wunderground and store in variable
    r = requests.get(ApiUrl)
    # take response and parse it into python dictionary object
    forecast = r.json
    # extract relevant data.
    # use variable to collect day of the week
    day = forecast['forecast']['txt_forecast']['forecastday'][0]['title']
    # display next day
    nextDay = forecast['forecast']['txt_forecast']['forecastday'][2]['title']
    # chance of rain
    rain = forecast['forecast']['txt_forecast']['forecastday'][0]['pop']
    rain = int(rain)
    # display current day
    print day
    #directly display the required info
    print forecast['forecast']['txt_forecast']['forecastday'][0]['fcttext']
    print nextDay
    # TEST CODE
    # print rain
    print forecast['forecast']['txt_forecast']['forecastday'][2]['fcttext']
    if rain >= 60:
        GPIO.output("P8_8",GPIO.HIGH)
    else:
    time.sleep(180)
# TEST CODE #
# prints entire json document
#print forecast
The data I need for the forecast is held in fcttext in 2 key / value pairs and this is displayed.
root@beaglebone:~# python text_forecast_v3.py
Monday
Mostly cloudy. Lows overnight in the low 40s.
Tuesday
Cloudy and becoming windy. Periods of light rain early. Turning colder. High 46F. Winds N at 20 to 30 mph. Chance of rain 40%.
Monday
Tuesday
Monday
Cloudy. Lows overnight in the low 40s.
Tuesday
Light rain early. Then becoming windy in the afternoon. Turning colder. High 47F. Winds N at 20 to 30 mph. Chance of rain 40%.
I am displaying this in the console at the moment, I might use some kind of GUI at a later date; my son odion is often telling me that I should put stuff into GUIs but A console is good enough for me for now image
The code to get the forecast could be run on any machine that can run python 2.7 but now we come to the reason for running this on the BBB. There is a single LED connected to P8-8 and when the value of the precipitation chance in percentage is over  60% this LED lights up. The whole check is done every 3 minutes at the moment but I will be playing with the timings later. It is likely that I can get away with every 6 hours or so but I will see.
I have taken the idea for this from the "Getting Started with Raspberry Pi" book and made a few changes as well as converting it to the BBB; I will probably set this up on the Pi next and see if there are any differences in the way it works.
The Weather Underground api looks very wide ranging and I will see what else I can get out of it, I think that as we in the UK head into winter something that pulls the expected maximum and minimum temperatures will be useful. I have found where this info is held in the json document:
"period":1,
"high": {
"fahrenheit":"48",
"celsius":"8"
"low": {
"fahrenheit":"41",
"celsius":"5"
Will have to play around with this info and see how I can make use of it.
I will be using my BB_VIEW display to see how I can display the info, not sure what or how yet, this will be in another blog. I am going to be writing about my experiences with my new Pi B+ so check out my blogs on there.
Bye for now, off to check if my LED is alight yet!
Beaglebone Black
BB View 4_3 LCD Display
    DAB over 11 years ago +1
    Good post. Where I live, I always carried an umbrella. Our weather was very changeable and afternoon thunderstorms were common during the summer. DAB
    DAB over 11 years ago in reply to markvenn +1
    Hi Mark, Set it up for Dayton, Ohio and you will get a good lesson in variable weather. We sometimes see temperature changes of 40 to 50 degrees F in the course of the day. Thanks. DAB
  • markvenn
    markvenn over 11 years ago in reply to DAB
    Dayton weather, 10 minutes apart, each line is :
    root@beaglebone:~# vi text_forecast_v3.py
    Thursday
    Cloudy skies. Slight chance of a rain shower. High around 40F. Winds E at 5 to 10 mph.
    Friday
    Showers early, becoming a steady rain later in the day. High 46F. Winds light and variable. Chance of rain 100%. Rainfall near a quarter of an inch.
    Thursday
    Friday
    Thursday
    Friday
    Thursday
    Cloudy. Slight chance of a rain shower. High near 40F. Winds E at 5 to 10 mph.
    Friday
    Showers early, becoming a steady rain later in the day. High 46F. Winds light and variable. Chance of rain 100%. Rainfall around a quarter of an inch.
    Thursday
    Friday
    Thursday
    Friday
    Thursday
    Friday
    Thursday
    Cloudy skies. Slight chance of a rain shower. High near 40F. Winds E at 5 to 10 mph.
    Friday
    Thursday
    Friday
    Thursday
    Friday
    Thursday
    Friday
    Thursday
    Generally cloudy. Slight chance of a rain shower. High near 40F. Winds E at 5 to 10 mph.
    Friday
    Rain showers in the morning will evolve into a more steady rain in the afternoon. High 47F. Winds light and variable. Chance of rain 100%. Rainfall around a quarter of an inch.
    Definitely need your umbrella tomorrow! image
    Hi Mark,
    Thanks.
  • markvenn
    Hi DAB
    Give me a town in your area and I will see what the data looks like! Extreme weather would be good to try.
    Good post.
