BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Blog E14 - BeagleBone Black 2.2" SPI Lcd interfacing fbtft
Join BeagleBoard to participate - click to join for free!
  • Author Author: gsgill112
  • Date Created: 22 Feb 2015 5:33 PM Date Created
  • Views 2688 views
  • Comments 6 comments
gsgill112
gsgill112
22 Feb 2015
Hi Guys image ,
First of all Thanks a ton Element14 for sending one of the BeagleBone Black to test image I recently have interfaced a 2.2" SPI LCD 240x320 To the Element14 Beagle Bone Black. Below is a Working demonstration of the Display in action
I also made a breakout board for the above featuring
1. Easy Plug and play capability (Modular design)
2. Easy UART Access using a Standard arduino mini FTDI module
Quick Observations,
1. The board is officially BeagleBone Black compliant !! Still No BeagleBone Black Logo is present on board ??
2. This board uses the Latest AM3358 Chip instead of AM3359 one on previous versions.
3. It is an Exact replica of the original BeagleBone Black, and works PREFECTLY.
4. Finally, By default the E14 BBB comes with Debian pre-installed, my old BBB 2G version came with Armstrong installed image
Thanks again to Element 14 for sending me a BeagleBone Black.
and please comment below if you want to know more.
  • gsgill112
    gsgill112 over 11 years ago in reply to e14 Contributor
    Hi Michael, It's work under progress, I am really busy with hell lot of things pending image but will try and finish the details by this weekend image you can find it first on "technervers.blogspot.in" and will post the same @E14 community a bit later image
    GurI
    Gsgill112
    Have you put together some sort of outline to follow to get this display to work?   The video is missing some details and is very difficult to follow.
  • gsgill112
    gsgill112 over 11 years ago in reply to clem57
    @Clem Martins Thanks, image image , Yes there's an SD card module, that does not share the same spi bus, I haven't interfaced that as for that have to write another application, preferably attach the SD to another spi bus on the BBB. For the 2.2" Example the DTO has definitions for the LCD SPI as well as a resistive touch screen (Although i don't have any touch panel connected)
    GurI
  • gsgill112
    gsgill112 over 11 years ago in reply to mdejong
    @Mark de Jong You can find all the info in the Video description. I have to write a easy to follow blog for it but that may take time, if you are not able to find any information there, please P.M. me.
  • clem57
    clem57 over 11 years ago
    gsgill112
      Great review! You turned the lcd over twice. Was that a SD card slot behind the lcd? Does it work with your current wiring? Is there an aproximate cost?
    Cheers,
    Clem
