BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Wireless cape issues
Join BeagleBoard to participate - click to join for free!
  • Subscribers 109 subscribers
  • Views 1187 views
phillipb0576
phillipb0576 over 9 years ago
I haven't had any success connecting the wireless cape to the Beaglebone black. Has anyone had success? If so, where can I find resources on how to prepare the Beaglebone Black to except the wireless cape? In going down the wireless cape rabbit hole I found several references to uploading SDKs to the SD card the BBB is booting off of and/or downloading/pulling various scripts. The issue I'm having is the card is reading as full of in the case of the SDK image described on TIs site the BBB Debian image is being wiped in the process of loading the SDK. I'm running Debian Jessie 9.1.
  • wleveugle
    0 wleveugle over 9 years ago
    Hello Phillip,
    I purchased two BBB and WCC and I am in the same case than you.
    The WCC are not recognised by the BBB...
    If you get some result about this, please inform me, I'll do the same If i make some progresses.
    best regards
    Will
    0 jw0752 over 9 years ago
    Hi Phillip,
    Did you happen to see this:
    https://www.element14.com/community/docs/DOC-83730/l/bbone-gateway-capereadme11292016v0-1pdf
    I don't know if it will help but it looked related to your issue.
  • gsgill112
    0 gsgill112 over 8 years ago
    Any update on someone getting it working with beagle bone black ?
  • gsgill112
    0 gsgill112 over 8 years ago in reply to jw0752
    YES, I have tried everything mentioned, in this pdf, as well as some online tutorials, but all in vain !
    //GS GILL
  • wleveugle
    0 wleveugle over 8 years ago in reply to gsgill112
    It's working for me (BBB and Connectivity Cape) !
    We were a bit dumb, we hadn't connect the power supply... The BBB can work with the USB provided power, but it's not enough to handle the cape, so you have to connect an external power supply.
    It's working for us since we've done this.
  • gsgill112
    0 gsgill112 over 8 years ago in reply to wleveugle
    @wleveugle
    Can you cover the exact steps you followed ??
    I am using an external 5V 3A Rated supply image
    GS GILL
