BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum BBB+LoRa
Join BeagleBoard to participate - click to join for free!
  • Answers 2 answers
  • Subscribers 108 subscribers
  • Views 2329 views
BBB+LoRa
littleben1
littleben1 over 8 years ago
I'm sure this probably has been covered before but can't seem to find it right now, so my question is, is there a cape for the BBB for Lora connectivity and if not what would be the simplest way to do so?? Thanks in advance
    shabaz over 8 years ago in reply to littleben1 +1 suggested
    Hi Benjamin, I've not tried it (with BBB), but you're right, one easy way to connect up would be with a mikroe board on the cape. But most LoRa boards just need power and a few wires connected, so even…
  • littleben1
    littleben1 over 8 years ago in reply to shabaz +1
    yeah I live out in the middle of nowhere, I figure when I get the modules I will take the node and drive away from home slowly to see how far it reaches. I'm wanting to use the BBB as the Home Base. Don…
  • littleben1
    0 littleben1 over 8 years ago
    there's a chance I answered my own question, I think I could go with the microbus cape and then add the LoRa click to give me the setup I'm looking for. Has anybody tried this before, and did it work at decent ranges??
    0 shabaz over 8 years ago in reply to littleben1
    Hi Benjamin,
    I've not tried it (with BBB), but you're right, one easy way to connect up would be with a mikroe board on the cape. But most LoRa boards just need power and a few wires connected, so even jumper wires could be used with most LoRa boards. The software would have to be written however, but there is example source code for different microcontrollers that could be modified or ported.
    Regarding range, it is great in an open area at low data rate. In a built up area normal rules apply, i.e. line of sight helps, antennas help, it may not be very far at all if you're in a building with a lot of metalwork, or if there is no line of sight and there are dense neighborhood areas or buildings around it. Positioned well (e.g. at the top of a building) it could cover large distances in cities too.
  • littleben1
    0 littleben1 over 8 years ago in reply to shabaz
    yeah I live out in the middle of nowhere, I figure when I get the modules I will take the node and drive away from home slowly to see how far it reaches. I'm wanting to use the BBB as the Home Base. Don't really need it to go far for my project but would like to see how far I can get out of it.
  • tom@origtech.com
    0 tom@origtech.com over 7 years ago
    There is a LoRa Cape module that's available for the BBB. See https://www.origtech.com/lora-cape.html  for more information.
