BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Beagle bone black is not booting from SD card
Join BeagleBoard to participate - click to join for free!
  • Subscribers 107 subscribers
  • Views 3235 views
  • beagle bone black is not booting from sd card
masea0805
masea0805 over 7 years ago
I am using beagle bone black element 14 board interfaced with CAN cape.
I downloaded the Debian 9 from beaglebone website and copied into SD card and tried to boot with boot button key in (CANcape) pressed before power supply but its not booting.
Actually the BBB is booting fine from eMMC.
When I tried to boot from SD I have observed the user LEDs are not blinking and also no logs in the serial console. I have no idea why it is not booting.
Kindly help me in resolving the issue.
Masea
  • grondak
    grondak over 7 years ago +1
    Hi masea0805 Did you try to boot the BBB without the cape? The instructions for booting with an SD card remind you, If you are using your Beagle with an SD (microSD) card , make sure it is inserted ahead…
  • grondak
    0 grondak over 7 years ago
    Hi masea0805
    If you are using your Beagle with an SD (microSD) card, make sure it is inserted ahead of providing power. Most Beagles include programmed on-board flash and therefore do not require an SD card to be inserted.
    I bet you already did this step, so see how the BBB works without the cape.
    If it still fails without the cape, but boots from the eMMC as you mentioned, maybe the card isn't built correctly? (Debian not copied into SD card properly).
    Maybe you can take a video of the failure and I'll compare it to my BBB to help.
