BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Requisite Stuffs for the BeagleBone AI Board
Join BeagleBoard to participate - click to join for free!
  • Replies 10 replies
  • Answers 4 answers
  • Subscribers 111 subscribers
  • Views 1906 views
  • beaglebone ai
journeyoflife
journeyoflife over 7 years ago
I am going to purchase the BeagleBone AI shortly.
What additional stuff are you recommend to run the BeagleBone AI?
Please inform me of a few candidates for the following extras.
(exact product name and maker name)
- Power Adapter.
- Cooling Fan or Cooling Fan Cape.
- USB-to-TTL 3.3V Serial Cable. (I am not sure that this item is required to develop an application.)
  • jomoenginer
    jomoenginer over 7 years ago in reply to journeyoflife +4 suggested
    I have the fan so it blows on the heat sink and with normal use the cores run below 35C. I do have the latest updates on the board though. The following I found on the web somewhere and will show the core…
  • jomoenginer
    jomoenginer over 7 years ago in reply to journeyoflife +3
    This is what is seen with the same script on a RasPi 4 with a good set of heat sinks and a larger fan than the X15FANKIT. $ ./get_temp.sh cpu-thermal 36.9°C
  • 14rhb
    14rhb over 7 years ago +2
    The connector for power is USB-C so make sure you have one otherwise the fun will stop for a few days
  • clem57
    0 clem57 over 7 years ago
    journeyoflifethis is a good power adapter because it is 5 ft and 18 AWG cable.
    https://www.amazon.com/CanaKit-Raspberry-Power-Supply-USB-C/dp/B07TYQRXTK/ref=asc_df_B07TYQRXTK/?tag=bingshoppinga-20&li…
  • gdstew
    0 gdstew over 7 years ago in reply to clem57
    The official Raspberry Pi 4 power supply has a 4.9 ft. (1.5m) cable and also uses 18 AWG wire. It is a 3A power supply and the one you link to is 3.5A so it has an advantage there.
    With a 3A - 3.5A power supply you need 18 AWG wire!
  • jomoenginer
    0 jomoenginer over 7 years ago in reply to clem57
    I second the CanaKit Power supply.  I got the one with the extra switch adapter though.
    For the fan, I got the X15 Fan Kit which seems to fit perfectly on the heat sink.
    Also, a Logitech C920 USB camera would be handy if you plan to the run through the TIDL example:
    https://www.amazon.com/Logitech-Widescreen-Calling-Recording-Desktop/dp/B006JH8T3S/ref=sr_1_1?hvadid=77653062118396&hvbmt=be&hvdev=c&hvqmt=e&keywords=logitech+webcam+hd+pro+c920&qid=1571721810&sr=8-1
  • sharath_n
    0 sharath_n over 7 years ago
    Hi, I have beagle bone AI. It gets heated very hot even with the fan attached. No heavy processing just by powering up.
  • journeyoflife
    0 journeyoflife over 7 years ago in reply to sharath_n
    Hello Sharath N,
    Thank you for letting me know your actual usage experience.
    It seems too early to apply the Beaglebone AI board to real applications.
    I do not understand that the BeagleBone Foundation does not yet have a cooling solution for the board.
    I recently became interested in an embedded Linux system and Beaglebone board to take advantage of my HW and SW knowledge.
    Of course I'm interested in AI.
    So I tried to buy the latest BeagleBone AI board as much as possible, but I think it would be more realistic to buy a BeagleBone Black Wireless board instead.
  • journeyoflife
    0 journeyoflife over 7 years ago in reply to jomoenginer
    Thank you for your information.
    Regarding the X15 fan kit, does the fan system properly cool the working board?
  • gdstew
    0 gdstew over 7 years ago in reply to journeyoflife
    In this discussion there is a bash script I wrote to read the BeagleBone Ai temperatures. You might find it useful.
    https://www.element14.com/community/message/283031/l/reading-beaglebone-ai-temperatures#283031
  • jomoenginer
    0 jomoenginer over 7 years ago in reply to journeyoflife
    The following I found on the web somewhere and will show the core temps which I placed in a script:
    paste <(cat /sys/class/thermal/thermal_zone*/type) <(cat /sys/class/thermal/thermal_zone*/temp) | column -s $'\t' -t | sed 's/\(.\)..$/.\1°C/'
    $ ./get_temp.sh
    cpu_thermal     35.0°C
    gpu_thermal     34.5°C
    core_thermal    35.0°C
    dspeve_thermal  33.0°C
  • jomoenginer
    $ ./get_temp.sh
    cpu-thermal  36.9°C
  • 14rhb
    0 14rhb over 7 years ago
    The connector for power is USB-C so make sure you have one otherwise the fun will stop for a few days image
