BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Use UART0 of pocketbeagle, disable boot and console
Join BeagleBoard to participate - click to join for free!
  • Subscribers 107 subscribers
  • Views 1951 views
chrischristian14
chrischristian14 over 6 years ago
Hi, I have designed a PCB with pocketbeagle as a module, I made a mistake and instead of UART 4 I have connected UART 0, before I cut tracks, I would like to explore option of using UART 0 for my application and UART4  for debug and boot, console. Can any one please guide me where I can change the UART for console and boot ? Please note that this is pocketbeagle and not BBB, I tried changing /dev/tty in  SOC.sh in /boot directory but that didn't make any difference. There is not other mention of tty in any of the files in /boot.
Thanks in advance.
  • rramesh1992
    0 rramesh1992 over 6 years ago
    Hello Chris,
    To Enable the UART, Please check the below common configuration procedure & this applies to Pocketbeagle also.
    To enable the uarts 1,2,4 and/or 5 on the BeagleBone Black, rev A, B and C:
    Rev A/B: Open the file /media/BEAGLEBONE/uEnv.txt in an editor (vim/nano)
    Rev C: Open the file /boot/uboot/uEnv.txt in an editor (vim/nano)
    Add the key "capemgr.enable_partno="
    Add the ports you want to enable, comma separated (BB-UART1, BB-UART2. BB-UART4, BB-UART5)
    Reboot
    An example line looks like this:
    root@beaglebone:/dev# cat /media/BEAGLEBONE/uEnv.txt
    optargs=quiet drm.debug=7 capemgr.enable_partno=BB-UART4
    After reboot, the device is present in the device list:
    root@beaglebone:/dev# ls -l /dev/ttyO*
    crw-rw---- 1 root tty     249, 0 Jan  1 01:18 /dev/ttyO0
    crw-rw---- 1 root dialout 249, 4 Jan  1 01:18 /dev/ttyO4
    then
    You need to set console=/dev/ttyS0 (swapping ttyS0 for the interface you would like to use) inside /boot/uEnv.txt
