BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum new BBB: bad uSD slot?
Join BeagleBoard to participate - click to join for free!
  • Subscribers 108 subscribers
  • Views 748 views
I just acquired an Element14 Beaglebone Black from Amazon. I've been trying to use the uSD card slot without success. If I interrupt U-Boot I get the following results
whether or not a properly formatted card is inserted (the card was written and verified on two separate systems). Please advise: should I return this board??
U-Boot# mmc dev 1
mmc1(part 0) is current device
U-Boot# mmc part
Partition Map for MMC device 1  --   Partition Type: DOS
Part Start Sector Num Sectors UUID Type
  1 2048       196608     00000000-01 0e Boot
  2 198656     7469056   00000000-02 83
U-Boot# mmc dev 0
Card did not respond to voltage select!
mmc0(part 0) is current device
U-Boot# mmc part
get mmc type error!
U-Boot#
  • clem57
    0 clem57 over 11 years ago
    Usually mmc is flash and sda is sd card. I will play with mine before commenting more.
    0 e14 Contributor over 11 years ago in reply to clem57
    ***I failed to flag this discussion as a question***
    Something is basically wrong (either with me or this device ;-)
    Here's the info at startup:
    U-Boot 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
    I2C:   ready
    DRAM:  512 MiB
    NAND:  0 MiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    *** Warning - readenv() failed, using default environment
    Net:   <ethaddr> not set. Validating first E-fuse MAC
    I  can't get U-Boot to save any environment variables, not even bootdelay. I've tried setenv, editted on /dev/mmcblk0p1 after the factory emmc boots, and via the gadget bridge on Windows but values there are never seen/saved by U-Boot.
    What am I doing wrong here???
  • clem57
    0 clem57 over 11 years ago in reply to e14 Contributor
    element14jamie can you make this a question as wkelleyg9753 wishes?
  • element14jamie
    0 element14jamie over 11 years ago in reply to clem57
    done image
    Thank you,
    Jamie
