BeagleBoard
  • Single-Board Computers
  • BeagleBoard
BeagleBoard
Forum Beaglebone Black Industrial conformal coating
Join BeagleBoard to participate - click to join for free!
  • Subscribers 104 subscribers
  • Views 1605 views
  • beaglebone black industrial
  • conformal coating
eduG
eduG over 3 years ago
Hi all,
Has the BBBI any conformal coating? The reference manual states "The element14 BeagleBone Black Industrial is based on the BeagleBone Black Rev C design and supports a wider operating temperature range and is conformally coated", but there is no reference about the coating used (brand/model)
As well, looking at a board, we cannot see clearly if there is any coating, and using an UV lamp does not show anything else (some coatings have UV markers that shine under UV lamp for visual inspection).
Thanks!!!!
  • eduG
    eduG over 3 years ago in reply to cstanton +1
    Looking forward to your answer! Thanks!
  • dang74
    dang74 over 3 years ago +1
    When I receive conformally coated boards from our manufacturing facility I find it difficult to probe because the coating covers the metal pins of the components. If you struggle to measure resistance…
  • cstanton
    cstanton over 3 years ago in reply to eduG +1 verified
    Hi eduG No, the beaglebone black industrial does not come with a conformal coating by default - if it did come with a conformal coating this was a very basic 'high temperature environment' coating, the…
  • cstanton
    0 cstanton over 3 years ago
    Hi eduG ,
    I'll reach out to the online store's single board computer team and I will try to discover an answer for you.
  • eduG
    +1 eduG over 3 years ago in reply to cstanton
    Thanks!
  • dang74
    0 dang74 over 3 years ago
    When I receive conformally coated boards from our manufacturing facility I find it difficult to probe because the coating covers the metal pins of the components.  If you struggle to measure resistance when you probe resistors on the board that would be one sign that the boards are coated.  On the other hand,  if it's easy to make resistance and continuity measurements across the board then I would think the board isn't coated.
  • cstanton
    0 cstanton over 3 years ago in reply to eduG
    Hi eduG
    No, the beaglebone black industrial does not come with a conformal coating by default - if it did come with a conformal coating this was a very basic 'high temperature environment' coating, the company may be able to do this for you as a paid-for service.
