RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Blog Installing Google Play Services and Google Play Store on RiotBoard
Join RIoTboard to participate - click to join for free!
  • Date Created: 14 May 2014 2:30 PM Date Created
  • Views 2691 views
e14 Contributor
e14 Contributor
14 May 2014
This short blog is for those android developers who which to install the Google Play Services and the Google Pay Store apps on the RiotBoard !!.
So the first we need is to download this applications:
GoogleLoginService.apk - www.dropbox.com/s/lfde3juixuy88rg/GoogleLoginService.apk
GoogleServicesFramework.apk - www.dropbox.com/s/9kurwyhbbuecaea/GoogleServicesFramework.apk
Phonesky.apk - www.dropbox.com/s/9x8924gtb52ksn6/Phonesky.apk
Then in order to install them, we will push them into /system/app, but first we must remount the file system and give the necessary permissions
to the /system/app directory. For this we will need the debug terminal through a cable from your pc to the J18 port on RiotBoard,
check this if you don´t know how (http://www.element14.com/community/thread/33742/l/how-do-i-access-the-terminal).
And then with PuTTY or HyperTerminal (check the manual on page 42) and type these commands:
- mount -o remount,rw -t yaffs2 /dev/block/mtdblock0 /system
- chmod 777 /system/app
The push we will do it through adb tool, in windows cmd we type
- adb push Each_of_the_3_apk_files.apk /system/app/
Once we did that we can download the Google Play services app - www.dropbox.com/s/bh058hbrelccfsr/com.google.android.gms-2.apk
and install it by typing  "adb install C:\PathToTheApp\com.google.android.gms-2.apk"
Now you just need to run the play store app and register your existing account or create one and that´s it !!! you can start downloading as many
apps as you want !!.
You can check the original post here http://saleh360.blogspot.mx/2012/12/android-running-google-maps-api-v2_12.html.
    e14 Contributor over 11 years ago in reply to toonamo +1
    Ok so yes the answer is to actually download the apps for your android version on Google Apps (Gapps) - Download Latest Gapps for Android , like you said but you need to have a rooted device ( Rooting…
    Ok so yes the answer is to actually download the apps for your android version on Google Apps (Gapps) - Download Latest Gapps for Android, like you said but you need to
    have a rooted device (Rooting Android for the RIoTBoard) and then
    For android version below 4.4:
    From gapps-*******-signed/system/app push GmsCore.apk, GoogleLoginService.apk, GoogleServicesFramework.apk and Phonesky.apk to /system/app/ by
    adb shell mount -w -o remount /dev/block/mmcblk0p5 /system
    adb push GmsCore.apk /system/app/
    adb push GoogleLoginService.apk /system/app/
    adb push GoogleServicesFramework.apk /system/app/
    adb push Phonesky.apk /system/app/
    For android version 4.4 and above:
    from gapps-*******-signed/system/priv-app push GmsCore.apk, GoogleLoginService.apk, GoogleServicesFramework.apk and Phonesky.apk to /system/priv-app/ by
    adb push GmsCore.apk /system/priv-app/
    adb push GoogleLoginService.apk /system/priv-app/
    adb push GoogleServicesFramework.apk /system/priv-app/
    adb push Phonesky.apk /system/priv-app/
    then you reboot the system and there you go !!, now you can go to the google play store and singed in with your google account and start downloading all the apps you can image
  • toonamo
    toonamo over 12 years ago
    The google play framework keeps crashing on me when ever i try to sign in, usually in-game. however i can log in and download apps from the app store fine. Any thoughts on what to check to make the framework happy again?
    -Update-
    I Downloaded a update gapps zip that is normally used to flash the android image to add google apps and services
    http://www.teamandroid.com/gapps/
    I then unziped the archive (becuase i couldn't figure out how to apply the zip towards the riotboard rom).
    I was going to manually install everything based on the install script. However because the system partition is so small i was not able to install everything. However i was able to get GoogleLoginService.apk in there which i believe was the piece that would make the google play service crash. now i am able to log in to google apps outside of the google play store.
    Hopefully that helps.
