RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum Running Linux on SD-Card
  • Subscribers 24 subscribers
  • Views 1023 views
Hi Guys,
is there a detailed description for burning an ubuntu image on the SD-Card? I have installed the existing linux image on the eMMC internal storage. Works fine! But unfortunately the amount of internal storage (4GB) is not enough for my project. What i want to do is install ROS (Robotic Operating System) and therefore i need more than 4GB storage. I have googled for several hours now and i only find an .sdcard file which probably contains a Linux image. But i don't know how to install this .sdcard image to the SD-Card from the Riot-Board. Can someone help me?
thanks
  • tusharp
    tusharp over 12 years ago
    we have a document here for flashing using linux.
    plz check this for flashing using windows
  • tusharp
    plz check this blog to setup a sdcard image.
      the image you need is located here :https://www.dropbox.com/sh/nuhzba8uqpijenb/AACDed0Npf23zSqtwjmq5qQka
      image : fsl-image-fb-riotboard.sdcard
  • tusharp
    to know more on flashing NAND and tweaking MFG Tool refer this blog by Otto.
    e14 Contributor over 12 years ago in reply to tusharp
    thanks for the very quick reply!!!
    I have read this tutorial already RIoTboard: Updating OS images in Windows Environment. But what line i have to put in the "cfg.ini" file that ubuntu will be flashed to the Sd-Card? I have try the following in the cfg file:
    [profiles]
    chip = MX6DL Linux Update
    [platform]
    board = RIOT
    [LIST]
    name = i.MX6DL-ubuntu-SabreSD-SD
    The Mfg tool stucks by "Loading u-boot" stepp. I have waited an hour and nothing happened in the status bar.
    The Riot Board was in the serial download mode.
    When use the "cfg.ini" file below the Mfg tool dont start correctly and throws an error.
    [profiles]
    [platform]
    board = RIOT
    [LIST]
    name = i.MX6DL-ubuntu-RIOT-SD
    any help?
  • tusharp
    tusharp over 12 years ago in reply to e14 Contributor
    you can avoid that MFG Tool altogether .
    check this blog : http://www.element14.com/community/community/designcenter/single-board-computers/riotboard/blog/2014/07/31/upgrading-riotboard-with-kernel-31017-windows-host
