RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum Transfer files to device
  • Subscribers 24 subscribers
  • Views 696 views
I want to use the RIoTboard as a server, but the Linux images on the official website are very minimalist. I'm having trouble with building my own image -- first attempt failed to boot -- so for now I want to make the minimalist system work. I can just transfer some binaries I compiled using Yocto, right? However, I'm not sure how I would go about the actual file transfer. Is it through Ethernet? If so, how?
  • tusharp
    0 tusharp over 10 years ago
    Plz check this blog series
    for yocto build check this, for linux build check this
    Right
    0 e14 Contributor over 10 years ago in reply to tusharp
    I've read those blogs already. I don't have a problem setting up a server. I installed the Ubuntu image the other day, which I didn't realise was a thing before, and it has enough tools to set things up. As for building a yocto image, I followed Freescale's user guide, which is pretty much the same as yours except for the versions. I'll try with older versions to see if it makes a difference.
    In any case, setting up a server isn't a problem now. I am still curious about how to do a direct Ethernet connection, though.
    EDIT: Just to be more specific, I used the x11 distro and core-image-base for building yocto.
