RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum Configure WIPI USB dongle in Android?
  • Subscribers 24 subscribers
  • Views 634 views
I have a RIOT board and been delighted on how easy it is to use.
I'm using Android and would like to get the WIPI working.
When I go into the settings and 'Turn on WIFI' I don't see any networks. I have tried refreshing, unplugging/replugging, on and off's, resets and checking all the wifi points locally and they are live.
Any suggestions on what this could be?
Regards
Steven
  • GregC
    0 GregC over 12 years ago
    Hi Steven
    Wipi/Wifi detection should be plug n play
    If your WiPi dongle doesn't detect properly the networks in the Android setup menu, I would flash a new Android image following Matt tutorial RIoTboard Demo I
    I just received a RiOT with a Linux BSP that I must replace by Android and a WiPi dongle, if you want, I can check it for you
  • tusharp
    0 tusharp over 12 years ago
    are those network open or with hidden SSID, for which you have to configure by setting SSID & passwd manually .
  • tusharp
    can you check if there is a max limit of no. of connected devices. once exhausted the access point may not allow more devices to be connected.
