RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum Problem in using the Linux BSP from element14
  • Subscribers 24 subscribers
  • Views 1291 views
  • riotboard
Nitin_Bhaskar
Nitin_Bhaskar over 12 years ago
Hi all,
I tried booting RiotBoard from SD card as described in this document. I used Linux.zip BSP. But I faced kernel panic issue,
sgtl5000 0-000a: Failed to get supply 'VDDD': -19
print_constraints: 0-000a: 850 <--> 1600 mV at 1200 mV normal
sgtl5000 0-000a: sgtl5000 revision 17
mmc0: new high speed DDR MMC card at address 0001
mmcblk0: mmc0:0001 MMC04G 3.57 GiB
mmcblk0boot0: mmc0:0001 MMC04G partition 1 2.00 MiB
mmcblk0boot1: mmc0:0001 MMC04G partition 2 2.00 MiB
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
mmcblk0: p4 size 5324800 extends beyond EOD, truncated
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
asoc: sgtl5000 <-> imx-ssi.1 mapping ok
imx_3stack asoc driver
asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
ALSA device list:
  #0: sgtl5000-audio
  #1: imx-hdmi-soc
NET: Registered protocol family 26
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
mmc1: new high speed SDHC card at address 1234
mmcblk1: mmc1:1234 SA04G 3.63 GiB
mmcblk1: p1
List of all partitions:
b300         3751936 mmcblk0  driver: mmcblk
  b301            8192 mmcblk0p1 00000000-0000-0000-0000-000000000000
  b302            8192 mmcblk0p2 00000000-0000-0000-0000-000000000000
  b303               1 mmcblk0p3 00000000-0000-0000-0000-000000000000
  b304         2621440 mmcblk0p4 00000000-0000-0000-0000-000000000000
  b305          524287 mmcblk0p5 00000000-0000-0000-0000-000000000000
  b306          524287 mmcblk0p6 00000000-0000-0000-0000-000000000000
  b307            8191 mmcblk0p7 00000000-0000-0000-0000-000000000000
  103:00000       8191 mmcblk0p8 00000000-0000-0000-0000-000000000000
b310            2048 mmcblk0boot1  (driver?)
b308            2048 mmcblk0boot0  (driver?)
b318         3813376 mmcblk1  driver: mmcblk
  b319         3805184 mmcblk1p1 00000000-0000-0000-0000-000000000000
No filesystem could mount root, tried:  ext3 ext2 ext4 cramfs vfat msdos
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,1)
[<80048834>] (unwind_backtrace+0x0/0xf8) from [<80514554>] (panic+0x74/0x18c)
[<80514554>] (panic+0x74/0x18c) from [<80008d58>] (mount_block_root+0x1e0/0x224)
[<80008d58>] (mount_block_root+0x1e0/0x224) from [<80008e84>] (mount_root+0xe8/0x108)
[<80008e84>] (mount_root+0xe8/0x108) from [<80008fc4>] (prepare_namespace+0x120/0x178)
[<80008fc4>] (prepare_namespace+0x120/0x178) from [<800089b0>] (kernel_init+0x108/0x13c)
[<800089b0>] (kernel_init+0x108/0x13c) from [<80042aa4>] (kernel_thread_exit+0x0/0x8)
Did anyone face similar issue?
  • hawkeyethehacker
    0 hawkeyethehacker over 12 years ago
    What filesystem was the SD Card formatted? (FAT32, ext4, etc) Have you tried re-writing the image to the card?
    Have you tried a different card?
  • Nitin_Bhaskar
    0 Nitin_Bhaskar over 12 years ago in reply to hawkeyethehacker
    I have followed exact steps mentioned in the document. The filesystem used was ext4. I have tried re-writing the image. But yet to try on different card.
  • Nitin_Bhaskar
    I tried on different card. But no luck. Same kernel panic image
  • hawkeyethehacker
    0 hawkeyethehacker over 12 years ago in reply to Nitin_Bhaskar
    Points to the download. Have you tried to redownload and reflash the system?
  • tusharp
    0 tusharp over 12 years ago
    can you try the latest sdcard image .
    I have posted a blog here.
  • Nitin_Bhaskar
    Well it looks like the issue is with the kernel. I compiled kernel from embest and re-flashed only kernel. It worked!!!
    Following are the steps I followed for kernel compilation.
    git clone git://github.com/embest-tech/linux-imx.git -b embest_imx_3.0.35_4.0.0
    make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- imx6_defconfig
    make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- uImage
    Cheers image
