RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Forum Linux header unmatched
  • Subscribers 24 subscribers
  • Views 1010 views
  • riotboard
  • linux
Hi there,
I've booted up a riotboard using the image in SVN2591 and everything seems fine. But when I check "uname -r" it returns "3.0.35-02881-g2ca0807-dirty" while the one inside "ls /lib/modules/" is 3.0.35-2508-g54750ff. No wonder I saw modprobe error in the dmesg, and the "lsmod" return nothing.
Anyone faced this?
Lawrence
  • tusharp
    tusharp over 11 years ago in reply to e14 Contributor +1
    in linux: setup directory: mkdir riot_github cd riot_github/ get sources: git clone git://github.com/embest-tech/fsl-linaro-toolchain.git git clone git://github.com/embest-tech/u-boot-imx.git…
  • tusharp
    0 tusharp over 11 years ago
    The kernel modules generated from 3.0.35-0288 are not updated in /lib/modules.
    so there's a mismatch image and modprobe error.
    if building kernel locally , copy the generated modules to the rootfs /lib & /usr/include folders.
    make modules
    make modules_install INSTALL_MOD_PATH=<ROOTFS_SDCARD_LOCATION>
    make headers_install INSTALL_HDR_PATH=<ROOTFS_SDCARD_LOCATION/usr>
    0 e14 Contributor over 11 years ago in reply to tusharp
    Hi tushar
    I did not build the kernel myself, but I would like to. Can you show me where can I get the source code?
    Lawrence
  • tusharp
    0 tusharp over 11 years ago in reply to e14 Contributor
    you can refer Riotboard User Manual Section5 to build custom images.
    Can you explain where can I get these two?
         Get the source code from dropbox
         Get the latest linux system source code from the below website and save to home
         directory:
         www.element14.com/riotboard
    What i found is image instead of the source code. Could you please help?
  • tusharp
    in linux:
    setup directory:
      mkdir riot_github
      cd riot_github/
    get sources:
      git clone git://github.com/embest-tech/u-boot-imx.git -b embest_imx_3.0.35_4.0.0
      git clone git://github.com/embest-tech/linux-imx.git -b embest_imx_3.0.35_4.0.0
    build u-boot
      cd u-boot-imx_3.0.35/
      export ARCH=arm
      export CROSS_COMPILE=~/riot_github/fsl-linaro-toolchain/bin/arm-fsl-linux-gnueabi-
      make mx6solo_RIoTboard_config
      make -j4
    build kernel & modules
    export PATH=~/riot_github/u-boot-imx_3.0.35/tools:$PATH
    cd ~/riot_github/linux-imx_3.0.35
    make imx6_defconfig
    make -j4 uImage
    make modules
    Once above done check below guide to setup sdcard;
    http://www.element14.com/community/docs/DOC-68087/
    Let me know if this helps.
    Tushar
