WaRP7
  • Single-Board Computers
  • WaRP7
WaRP7
Blog Warp7 Yocto : Part1 : setup, configure and generate Warp7 binaries
Join WaRP7 to participate - click to join for free!
  • Author Author: tusharp
  • Date Created: 16 Sep 2016 7:30 AM Date Created
  • Views 9980 views
  • Comments 89 comments
  • tusharp
  • imx7
  • yocto
  • image
  • bitbake
  • warp7
  • embedded
  • yocto-bsp
  • linux
tusharp
tusharp
16 Sep 2016
Contents
1. Warp7 Yocto Part1 <-- You are here
2. Warp7 Yocto Part2
3. Warp7 Sensors demo - mpl3115a2
4. Warp7 Sensors demo - fxos8700cq
5. Warp7 IoT demo
The Warp7 is a next generation Wearable and IoT development platform.
plz refer  NXP and element14 website for more platform related information.
Warp7 Board
CPU Board
IO Board
In this blog we will
1. Download warp7 yocto sources.
2. Setup required environment.
3. add/customise warp7 machine configs.
4. Compile and generate binaries.
A bit on yocto before we start :
If you are new to yocto , plz make sure to check the yocto project before proceeding.
Platform Setup:
I am using Ubuntu 14.04 x86_64 for the build process. you can use do this from a Virtual Machine (vmware, virtualbox) also.
We need to install some packages on which yocto depends for the build process.
sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib build-essential chrpath socat libsdl1.2-dev \
xterm sed cvs subversion coreutils texi2html python-pysqlite2 help2man make gcc g++ desktop-file-utils libgl1-mesa-dev \
libglu1-mesa-dev mercurial autoconf automake groff curl lzop u-boot-tools
Download repo:
We need to have a repo tool to pull yocto sources.
mkdir ~/bin
curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
chmod a+x ~/bin/repo
export PATH=~/bin:$PATH
Download Yocto:
following steps will help download yocto sources from NXP(Freescale) official repository:
mkdir warp7_yocto
cd warp7_yocto
repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b krogoth
repo sync
Before building the yocto bsp we need to update the yocto build with warp7 config.
To configure we need to pass the proper MACHINE name as a macro.
Determine machine name:
echo; ls sources/*/conf/machine/*.conf | sed s/\.conf//g | sed -r 's/^.+\///' | xargs -I% echo -e "\t%" | grep imx
The Warp7 machine name is imx7s-warp .
Setting up the environment:
MACHINE=imx7s-warp source setup-environment build
Select "Y" to accept the EULA license and complete the machine config setup.
Now a build directory is created under ~/warp7_yocto directory.
It contains the build system settings for warp7 machine(i.e local.conf) and yocto bitbake layers path information (i.e bblayers.conf).
local.conf
bblayers.conf
Customise warp7 machine config:
Now edit the kernel source in warp7 machine configuration file.
in ~/warp7_yocto/sources/meta-fsl-arm-extra/conf/machine/imx7s-warp.conf file, edit as below.
Replace
PREFERRED_PROVIDER_virtual/kernel ?= "linux-fslc-imx"
with
PREFERRED_PROVIDER_virtual/kernel ?= "linux-warp"
Now the kernel source will be pulled from the linux-warp%%  bitbake recipe.
Create a directory named "linux-warp7-4.1" and recipe named "linux-warp7_4.1.bb" in below path.
~/warp7_yocto/sources/meta-fsl-arm-extra/recipes-kernel/linux/
mkdir ~/warp7_yocto/sources/meta-fsl-arm-extra/recipes-kernel/linux/linux-warp7-4.1
touch ~/warp7_yocto/sources/meta-fsl-arm-extra/recipes-kernel/linux/linux-warp7_4.1.bb
Populating warp7 recipe:
populate the recipe "linux-warp7_4.1.bb" with below contents.
# Released under the MIT license (see COPYING.MIT for the terms)
include recipes-kernel/linux/linux-imx.inc
include recipes-kernel/linux/linux-dtb.inc
DEPENDS += "lzop-native bc-native"
SRCBRANCH = "4.1-1.0.x-imx"
SRCREV = "fa571312b4271e368ca99ffcdf7992247d534e55"
SRC_URI = "git://github.com/WaRP7/linux-fslc.git;branch=${SRCBRANCH} \
           file://defconfig"
COMPATIBLE_MACHINE = "(imx7s-warp)"
In above recipe we setup 4.1-1.0.x-imx as source branch for our kernel and file defconfig will be the default kernel config file.
Next copy the defconfig file (in attachment) into the linux-warp7-4.1 directory.
Downloading yocto packages:
If you want to build images offline, its a good idea to download the packages first.
bitbake core-image-minimal -c fetchall
Build:
Now build, it will take several hours to complete depending on your PC configuration.
While kernel build is in process you might encounter an error wrt imx7s-warp.dtb.
This will happen is there is no imx7s-warp.dts file in below directory.
~/warp7_yocto/build/tmp/work/imx7s_warp-poky-linux-gnueabi/linux-warp7/4.1-r0/git/arch/arm/boot/dts
below is a snapshot from the log file that captured the above  error.
In that case copy the imx7s-warp.dts from the attachments to the below directory:
Now hit build again.
After build completed, the images build are found in ~/warp7_yocto/build/tmp/deploy/images/imx7s-warp
Let us know any challenges faced during build procedure through comments.
Next time we will flash the generated images.
Happy Warping.
warp7_attachments.zip
  • bwelsby
    bwelsby over 9 years ago in reply to Jan Cumps +1
    Jan Cumps wrote: bitbake -fetch finished successful (14 hours on the raspberry pi to complete all 189 jobs. it used 4 job threads to allocate tasks on this board), now up to the next step: build That's…
  • bheemarao
    bheemarao over 9 years ago +1
    I tried building the same as shown steps below bheema@Bheema:~/warp7_yocto$ MACHINE=imx7s-warp source setup-environment build-warp7 then by default the kernel will fetch from "include recipes-kernel/linux…
    Jan Cumps over 9 years ago in reply to Jan Cumps +1
    Installing the dependencies. Once I'm at the bitbake line, I'll switch to bheemarao 's steps...
  • rushin010
    rushin010 over 9 years ago in reply to tusharp
    After that i got error like
    rushin@rushin-VirtualBox:~/warp7_yocto/build$ bitbake core-image-minimal -c fetchall
    Loading cache: 100% |##########################| ETA:  00:00:00
    Loaded 2199 entries from dependency cache.
    NOTE: Resolving any missing task queue dependencies
    Build Configuration:
    BB_VERSION        = "1.30.0"
    BUILD_SYS         = "x86_64-linux"
    NATIVELSBSTRING   = "universal"
    TARGET_SYS        = "arm-poky-linux-gnueabi"
    MACHINE           = "imx7s-warp"
    DISTRO            = "poky"
    DISTRO_VERSION    = "2.1.2"
    TUNE_FEATURES     = "arm armv7ve vfp thumb neon       callconvention-hard       cortexa7"
    TARGET_FPU        = "hard"
    meta
    meta-poky         = "HEAD:cca8dd15c8096626052f6d8d25ff1e9a606104a3"
    meta-oe
    meta-multimedia   = "HEAD:851a064b53dca3b14dd33eaaaca9573b1a36bf0e"
    meta-fsl-arm      = "HEAD:a85fa8bf68517ca5cd9bb00bf792f54016799bed"
    meta-fsl-arm-extra = "HEAD:e95f4ae61fdaf6452d6dfa9cb59dbdf9cdf73c99"
    meta-fsl-demos    = "HEAD:a165068f8a0d1cf29aabe4b4053f28be1c2aa492"
    NOTE: Preparing RunQueue
    NOTE: Executing RunQueue Tasks
    WARNING: linux-warp7-4.1-r0 do_fetch: Failed to fetch URL git://github.com/warp7/linux-fslc.git;branch=4.1-1.0.x-imx, attempting MIRRORS if available
    ERROR: linux-warp7-4.1-r0 do_fetch: Fetcher failure: Fetch command failed with exit code 128, output:
    fatal: The remote end hung up unexpectedly
    fatal: early EOF
    fatal: index-pack failed
    ERROR: linux-warp7-4.1-r0 do_fetch: Function failed: Fetcher failure for URL: 'git://github.com/warp7/linux-fslc.git;branch=4.1-1.0.x-imx'. Unable to fetch URL from any source.
    ERROR: Logfile of failure stored in: /home/rushin/warp7_yocto/build/tmp/work/imx7s_warp-poky-linux-gnueabi/linux-warp7/4.1-r0/temp/log.do_fetch.2551
    ERROR: Task 5 (/home/rushin/warp7_yocto/sources/meta-fsl-arm-extra/recipes-kernel/linux/linux-warp7_4.1.bb, do_fetch) failed with exit code '1'
    WARNING: pseudo-native-1.7.5-r0 do_fetch: Failed to fetch URL http://downloads.yoctoproject.org/releases/pseudo/pseudo-1.7.5.tar.bz2, attempting MIRRORS if available
    ERROR: pseudo-native-1.7.5-r0 do_fetch: Fetcher failure: Fetch command failed with exit code 4, output:
    wget: unable to resolve host address 'downloads.yoctoproject.org'
    ERROR: pseudo-native-1.7.5-r0 do_fetch: Function failed: Fetcher failure for URL: 'http://downloads.yoctoproject.org/releases/pseudo/pseudo-1.7.5.tar.bz2'. Unable to fetch URL from any source.
    ERROR: Logfile of failure stored in: /home/rushin/warp7_yocto/build/tmp/work/x86_64-linux/pseudo-native/1.7.5-r0/temp/log.do_fetch.2685
    ERROR: Task 4 (virtual:native:/home/rushin/warp7_yocto/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_fetch) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 185 tasks of which 183 didn't need to be rerun and 2 failed.
    Waiting for 0 running tasks to finish:
    Summary: 2 tasks failed:
    Summary: There were 2 WARNING messages shown.
    Summary: There were 4 ERROR messages shown, returning a non-zero exit code.
  • rushin010
    hi thanks for support
    i tried that. but when i start bitbake, 189 tasks are executing and after 184 tasks ,i am not getting error but no progress in tasks. after 6-7 hours no progress in tasks. can you tell me what is problem??
  • tusharp
    tusharp over 9 years ago in reply to rushin010
    can you try this:
    1. manually download  http://downloads.yoctoproject.org/releases/pseudo/pseudo-1.7.5.tar.bz2
    2. copy that to yocto downloads directory.
    3. now create a file pseudo-1.7.5.tar.bz2.done in downloads directory.
    4. now start bitbake, it should work image.
  • rushin010
    hello there i did steps as described above. but i am getting error like that.  i repeated steps many times. but getting same error
    rushin@rushin-VirtualBox:~/warp7/warp7_yocto/build$ bitbake core-image-minimal -c fetchall
    Parsing recipes: 100% |########################| ETA:  00:00:00
    Parsing of 1664 .bb files complete (0 cached, 1664 parsed). 2198 targets, 189 skipped, 0 masked, 0 errors.
    DISTRO            = "poky"
    TARGET_FPU        = "hard"
    meta
    meta-oe
    fatal: early EOF
    ERROR: Logfile of failure stored in: /home/rushin/warp7/warp7_yocto/build/tmp/work/imx7s_warp-poky-linux-gnueabi/linux-warp7/4.1-r0/temp/log.do_fetch.2521
    ERROR: Task 5 (/home/rushin/warp7/warp7_yocto/sources/meta-fsl-arm-extra/recipes-kernel/linux/linux-warp7_4.1.bb, do_fetch) failed with exit code '1'
    ERROR: Logfile of failure stored in: /home/rushin/warp7/warp7_yocto/build/tmp/work/x86_64-linux/pseudo-native/1.7.5-r0/temp/log.do_fetch.2637
    ERROR: Task 4 (virtual:native:/home/rushin/warp7/warp7_yocto/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_fetch) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 185 tasks of which 176 didn't need to be rerun and 2 failed.
